SPT Portable is not working. Just making a very distinct electrical hum (60 cycle). Seems stuck in pumping cycle
farfield
  • 462 Answers
SOURCE: CARRIER MODEL 38YCA030370 MAKES HIGH PITCH ELECTRICAL HUMMING NOI
Yes it could be the pop off pressure relief on the compressor.
I assume it is the outdoor fan your referring to not running.
If this is a heat pump and it is in defrost (only in the heating mode should your outdoor fan be off and then for only a max of 12 to 15 minutes).
If it is just AC ir is Heat pump in cool mode, the out door fan should run while the compressor and indoor fan are on. Until the thermostat is satisfied on room temp.
This high pitched squealing is indicative of a bad fan motor or capacitor for the out door fan motor. Kill power and test blades to see if turns free. Check the run capacitor inside control panel. It is usually silver or aluminum colored (some are painted gray). The top should be flat with rolled edges and the sides should either be round or oval shaped with no swelling or oil leaking from inside it. If this all looks normal take it to where your going to get a motor any way and ask them to check it or sell you a replacement at the same time. These can go out usually from high voltage (lighting...) or from over heating (bad fan motor, dirty out door coil...).
Hope this helps you if not post back I'll respond as soon as I can. And please rate me as high as you can. Thank you for using Fix ya and good luck.
Posted on Mar 28, 2009
landsend
  • 1066 Answers
SOURCE: My Kenmore top load washer seems to be stuck - in
is the timer moving?  If not it broken and may need a new motor or a new timer assembly
Posted on Apr 01, 2009
  • 8404 Answers
SOURCE: little gray box electric timer. the clock dial
You may need to replace the timer motor. I believe you can purchase this part directly from the little gray box company - not their name, as you know - Find the company name on the label inside the box.
Thanks for your question at FixYa.com
Please vote when given the opportunity.
thanks
Posted on Dec 20, 2009
technical114
  • 1851 Answers
SOURCE: BUZZING NOISE LIKE 60 CYCLE HUM, CHECKED CORDS AND MIXER AND POWE
When the speaker is connected only at the power line does it makes this noise?
  • If it does it's an internal amplifier's ploblem and you have to check out some fittings (electrolytic capacitorsat the power supply, power supply transformer, voltage stabilizers e.t.c.)
  • If the speaker is quiet you have to check your external wiring because there is a loop ground. That means that one "ground level" line is connected at the ground by two or more cables (e.g. the audio ground and the grond from the mains power source) In this case disconnect the second (and the 3rd e.t.c.) grounding point.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 10, 2010
SOURCE: My portable top load kenmore
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Posted on Sep 27, 2010
I have asked my question twice It has not been answered yet WHY?
Hard call without seeing the failure.
No hot water? Does the heating light come on? If so, then the element is gone. Not economical to replace it.
Humming sound? What frequency? Is it a pump that runs continuously? If a tube is broke, it might be repairable. A bad pressure sensor will not be.
If the sound is a 60 cycle low hum you may have an electrical failure and possibly a dangerous machine. A wiring problem has a small possibility of repair.
Apr 25, 2014 | Keurig Elite B40 Coffee Maker
Viking spa speaker issues
sounds like something got wet your getting a 60 cycle hum from electric disconnect radio or replace radio hum is coming from amp in radio
Mar 15, 2014 | Pool & Spa
My ice maker will work 1 cycle and then it wont work again for a few days. I can here the compressor start up and it hums for 10 seconds then a click happens and its over. No more humming.
Compressor over load switch is the clicking you here. check the compressor to see if it has a start capacitor if so check to see if it is good. if it dose not have one then check compressor relays make sure there in good working order.
Jul 01, 2013 | Sunpentown SPT IM-100 Portable Ice Maker,...
Add water light stays on when the reservoir is full
I have the SPT IM-100 Portable Ice Maker. After about 2 months, it stopped, telling me that it needed water, when of course it was full of water. I did alot of digging on the Internet to find a solution. There was none. It finally occurred to me that the water sensor might be calcified with our hard water here in Reno. BINGO!!!! I ran several cycles with lemon juice and vinegar (you pick your favorite non-toxic acid), and the damned thing started up again as if brand new.
Jul 24, 2011 | Sunpentown SPT IM-100 Portable Ice Maker,...
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a General Electric WJRR4170E1WW top loading washer that occasionally hums when it is running but the agitator doesn't turn. When it does this it will go all night in this mode and get stuck. We can...
sound like a stuck timer does it in all cycles!!!!!!!!!! permanet press cycle , regular cycle
if it does it in all cycles then definetly timer...
Jan 31, 2011 | Washing Machines
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
