Question about Garden
Can you please tell me the air gap between coil and flywheel on a sthill chain saw and flywheel nut size thanks
    Master:
  • 923 Answers
Use a flexible feeler gauge to measure the gap. The magneto gap for any 2-cycle engine chain saw should 12-18 thousands of an inch. The gap is much less important than simply NOT HITTING the coil frame at any point on the flywheel. The nut is probably metric but I cannot tell you what size it should be. BE CAREFUL! Some chain saws have LEFT HANDED THREADS on such shafts! But you can usually tell by studying the protruding threads at the nut ... if there are any!
Posted on Apr 26, 2017
I'd like to know what steps to take to replace the contact points on a 1978 Poulan Micro XXV Super Deluxe 14" chain saw
Its a long time since i saw one of these, however, start by removing the starter cover screws and the starter itself, you need to remove the flywheel nut,1/2 spanner as far as i remember, strike the non magnet side of the flywheel with a suitable hammer, the flywheel should just pop off, remove the points back plate cover, this should just pull off, the points and condensor are all one peice, held with two screws, either clean the points or replace the assembly, the back plate will have slots to allow you to set the points gap, the gap is between 12 and 15 thousands of an inch, put a small amount of grease on the felt pad against the cam, refit the flywheel and nut, take care to re fit it onto the woodruff key properly, the air gap between the coil and the flywheel should be set at approx 0.5mm, re fit the starter and check for a spark.
Apr 02, 2011 | Poulan 14" Chainsaw
HOW TO TEST IGNITION COIL ON A POULAN CHAIN SAW MODEL 2000? ALSO WHAT IS THE AIR GAP ADJUSTMENT FOR THE SAME?
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
16'' chain Saw wont fire
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Lou
May 02, 2010 | Garden
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: need gap for magneto adj....
Ignition module gap
Lou
Apr 27, 2010 | Poulan Garden
Flywheel to mag. clearance
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | Homelite ZR10926 16" Chain Saw
What is the gap for the ignition module on a poulan wild thing chain saw?
Ignition module gap
Lou
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
