Question about Water Water Heaters
My water heater is a Marey - Water Water Heaters
4 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: constant water leak from the
That is the temperature pressure relive valve (TPV) . It is either foiled with some thing or going off because of a pressure or temperature problem. If it is leaking continuously it is foiled and needs cleaning. If I where there I would replace it with new.
Posted on Feb 08, 2011
SOURCE: I have a Marey LPG
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Posted on Apr 05, 2012
SOURCE: What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Posted on Jun 23, 2017
Jun 23, 2017 | Water Water Heaters
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
HOW DO YOU THE FRONT COVER OFF A 16L WATER HEATER
you remove the knobs by pulling them. then underneath the heater there are 2 screws on each of the back corners. will be inside a little as noy flush with the bottom of the heater. then pull the cover towards you at the bottom until it clears enough to then push up to come out of the top taps.
Sep 22, 2016 | Marey Heater Corp Tankless hot water...
My Marey tankless water heater will not ignite for the shower, but will forthe faucets. Have changed batteries, cleaned the filter and had the showerhead cleaned. Local plumbers will not do...
Most on demand or tank-less units require a minimum flow rate before the unit will fire up, they designed them that way so small water leaks (drips etc.,) keeps the unit from going on needless;y. Try opening the shower hot water fully and see if it comes on, If it does, try closing it slowly to see where it shuts off. Make sure your shower head is clean and not blocked with calcium, which will restrict the water flow. You could also try changing the shower head to one that allows more gallons per hour flow rate. Also make sure the cold inlet and hot outlet valves on the unit are fully open and the diverter on the shower is fully open as well.
Mar 24, 2015 | Water Water Heaters
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one out....my Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
I have Marey nat.gas.water heater (3 years old) now the flame goes on for a second and goes off ,pezo try to restarted but wont go back on ,any solutions ?? many thanks
Sounds like your thermocouple is shot.It's that
little tube that the pilot light heats up.I am
assuming that you have started this heater
before.The thermocouple has to stay a certain
temperature to keep the gas flowing.You can buy
universal thermocouple kits at your local
hardware store.Make sure gas is turned
off.Loosen the coupling nut on the outside of
the tank then remove the tin and remove the
heating part.The whole thing is a small 1/8
tube.Bend new one like the old one and put it
back in place.If the kit has yellow Teflon tape
wrap the threads on the coupling and
tighten.Turn the gas back on and test for leaks
with soapy water.Thanks for choosing FixYa.com.
I always add this for your information. If this
is not the solution that you are looking for
please re post because when we pick a question
to answer FixYa takes it out of the questions.
May 22, 2011 | RTO Ng Gas Tankless Water Heater - By...
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Constant water leak from the valve that came in the MAREY water heater
Feb 08, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
