Question about Sharp Televison & Video
I have a Sharp TV model number LC-42D62U. Has sound but no picture.
Has no back lights but a faint picture shows up with the flash light test. Has 2 back light inverter boards so how do I determine which one is bad?
  • 195 Answers
SOURCE: sharp LC 42D62U has sound no picture
Most likely the CCFL inverter is bad.
Posted on Oct 10, 2009
  • 8457 Answers
SOURCE: no picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Posted on Dec 28, 2009
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Posted on Feb 24, 2011
SD Tech
  • 14553 Answers
SOURCE: sharp Lc-42d62u lcd 42 in. tv has sound with solid blue screen no picture
Try to unplug the set to allow it the chance to reset the micro it uses--for a while or even overnight---Also with the model call Sharp to see if this is a known issue with this model or if there is a way to do a manual hard reset of the TV.
Posted on Apr 24, 2012
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp aquos picture goes out repair
These blinks [flahses] are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LCD panel is perfect with no dead pixels, however: When you switch it on, screen comes up briefly, then goes off, with flashing red light. LCD TV Sharp LC-42DH77E model any help very much...
Sounds like a power supply problem - take off the back check voltages coming from power supply if they are good check your inverter board to make sure they are good.
Thanks,
michael
Mar 25, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The power light and OPC light flash but TV won't turn on. On my Sharp Aquos LC-C5255U
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Jun 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U Completely Without Power
If you have no power at all , the then problem concern the power cord or the power supply board.
You need to test the power cable first, and eventually test and replace the power board, the job can be done by any local technician.
Here the replacement power board.
Here all parts for your set: LC-42D62U.
Mar 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a brand new Sharp LC-42D62U 32" HDTV.
it has a problem with the main board, i would call the place you baught it, they will eather exchange your tv, or tell you to call sharp, at any rete, it is under manufacturers warinty, and everything is covered for a year
Jan 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
