Question about Water Water Heaters
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
  • Water Master
  • 19,622 Answers
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Posted on Apr 26, 2017
We need to find out what is wrong with our hot water heater. It is a Marey 180. It quits heating water. You can cut it off for several hrs then cut it back on and it will heat again
Hello, busby_betty -
Clarification: You have a Marey ECO180 Electric Tankless Water Heater. If so, I checked the owner's manual, here:
https://marey.com/english/products/electric-water-heater/whole-house/eco180.html
in case your problem was mentioned in the Troubleshooting section. It wasn't.
Therefore, before you call for a repair technician to come and evaluate your water heater, I suggest you telephone the Marey Customer Service number: 855-627-3955 to find if the Customer Service representative has any ideas on what needs fixing. Or, you can send an email: customerservice@marey.com .
When you contact Marey Customer Service, ask about the nearest authorized Marey water heater service business, so you may call and make an appointment for a service technician to come to your home and check what is wrong and repair it.
If you were hoping an authorized Marey water heater repair person was sitting on Fixya.com waiting for questions about Marey water heaters, that isn't the case.
Note: It may be a problem with the water heater thermostat or the or the heating sensor. Also, check the information here:
https://www.doityourself.com/forum/water-heaters/548564-help-marey-electric-water-heater.html
(Copy the URL and paste it into the address box of your browser, if it isn't hightlighted as a link.)
The real problem may be with the electrical wiring and circuit to which the water heater is connected.
Jan 04, 2018 | Water Water Heaters
What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Jun 23, 2017 | Water Water Heaters
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one out....my Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
Propane hot water heater
Troubleshoot service manual by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Post question on following link:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you discover
Jun 28, 2013 | Water Heaters
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Recently installed a Bosch 2700ES. I am getting
unplug power or turn off power,reboot, and try again
Jul 04, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
95 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
