Question about Grilling
Can I convert a Umarex '94 L/A CO2 rifle to compressed air?
I use a lever action Walther in my shed for training for lever action competition c/fire & rimfire matches. I find that when I screw a new 88g bottle in & fire 20 rounds then put it away for a day or 2 the gas has all gone. I have thought of turning off the end of an empty gas tank & welding an adapter to the inside of it to take a quick connect fitting & valve, regulating it to about 1000psi. Has any one done such a conversion or has a better idea please?
Therinnaiguy
  • 1420 Answers
SOURCE: Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Posted on Sep 17, 2007
  • 210 Answers
SOURCE: lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Posted on May 31, 2008
jyackle5
  • 8197 Answers
SOURCE: Weber Q300 - Gas bottle runs out very quickly
Yes turn the valve off at the tank so you do not loose gas. You do not have to disconnect the tank from the BBQ though.
Good Luck and Please Rate FixYa!
Posted on Dec 28, 2008
electrodynam
  • 35 Answers
SOURCE: GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Posted on Mar 16, 2009
Adrian762
  • 425 Answers
SOURCE: Convert fixed SKS fixed magazine to removable 20
I think if you watch this video you may be enlightened:
http://www.wonderhowto.com/how-to/video/how-to-disassemble-and-reassemble-an-sks-carbine-rifle-269754/
Posted on Feb 13, 2010
Hello anybody know
Yes, I do but please don't post disjointed posts like this one. You can bring your original post up be clicking Want Answer. If you rally want to repost, elaborate on what you said before.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... date of manufacture and value: Click here to go to our gun values resource links.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
determining date of manufacture and value: Click here to go to our gun values ..... *TOO POST-64 MODEL 94 BEGAN WITH SERIAL NUMBER 2,700,000.
Winchester Model 94 Serial Numbers - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, winchester model 94 values, Winchester 1894, winchester model 94 prices, model 94 rifle, winchester lever action, 30-30 lever action.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden Memorial ... and find dates and serial numbers on The Winchester Model 94 30 30 ? ... I am thinking of trading the rifle for a 270 or 308 but want to verify its value. Winchester 94 w/no serial 18 posts 2 Oct 2007 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Blue Book of Gun Values - WINCHESTER FACTORY WINCHESTER ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
Add $50-$75 over individual prices for consecutively serial numbered rifle and ..... Model 94 rifle in .30-30 Win. cal. with octagon barrel, extensive C. Giovanelli scroll ... Other special issue receivers were used that bear this serial number as the ...
What Is The Year And Value Of My Winchester Model 94 Serial Number ...
www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester-model-94-s...
  1. Cached
  2. Similar
May 7, 2010 - I have a winchester model 94 30/30 lever action rifle . The serial number is 1208774. It is in mint condition. I was wondering what this gun is worth. Reply. avatar. Winchester Model 94 Pre 1964 Serial Number 1105022 4 Nov 2012 Where Is The Serial Number Located 31 May 2010 Winchester Model 94 8 May 2010 Winchester Model 94 30 Wcf Pre-64 6 May 2010 More results from www.gunvaluesboard.com
Value Of A Model 94 Winchester Rifle 30-30 Serial Number Is ... ' Gun ...
www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30-serial-numbe...
  1. Cached
  2. Similar
hey wiz sorry to interrupt and i know it is rude but i have a very poor money situation and need to sell this similar winchester model 94 30-30 the serial # is ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Jan 08, 2017 | Cell Phones
Can you tell me the model of my 270 winchester rifle serial number is G1871685
This is more specific to decoding your serial number as the other information I gave was on your Model 70.
[PDF]Winchester Firearms Manufacturing Dates By www.winchesterguns.com/.../winchester.../serial-number.../Winchester-M...
  1. Cached
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. The following pages were scanned from documents ...
What year was my Winchester manufactured? (Serial ...
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. Below is the download link for a special resource for ...
  1. Cached
  2. Similar
Dates ' Winchester Collector
winchestercollector.org/dates/
  1. Cached
  2. Similar
When was Your Winchester Made? ... Serial Number ... the dates of manufacture shown were obtained from the original Winchester Factory Polishing Room ...
Winchester Serial Numbers - ProofHouse.com
www.proofhouse.com/win/index.html
  1. Cached
  2. Similar
Main Page. Lever Action Rifles Slide Action Rifles Bolt Action Rifles Semi-Auto Rifles Shotguns Military Misc. Lever Action Rifles top. Walter Hunt's Repeater
Winchester Dates - ProofHouse.com
www.proofhouse.com/win/winchester.htm
  1. Cached
Serial numbers of the Henry rifle overlap those of the model 1866 from 1865 to 1866. .... George Watrous, a Winchester employee, counted total production at ...
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ...
Winchester Model 1894/94 Dates of Manufacture
www.savage99.com/winchester1894_dates.htm
  1. Cached
  2. Similar
Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
Date Your Model 70 and 94 - RifleShooter
www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803/
  1. Cached
  2. Similar
Nov 3, 2010 - We bought a Winchester model 70 with serial number G1741812. ... Kurt. Where can I find manufacture dates for Winchester Model 1894 rifles?
Winchester Model 1894/94 Factory Records - Shooters Forum
https://www.shootersforum.com/winchester.../67350-winchester-model-1...
  1. Cached
  2. Similar
Aug 12, 2010 - 7 posts It should now very clearly show the progression of verified dates of manufacture. I do not plan to add any additional new serial numbers to the ...
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
May 01, 2016 | Optics
Walther 1250 dominator .22 valve leaks
Call Umarex and talk to them, they are real nice people and are in business because you buy their product.
Feb 09, 2013 | Walther 1250 Dominator - 0.220 Caliber
How to repair a ruger air hawk .177
well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
Just purchased a crosman walther PPK/S air pistol 4.5mm at garage sale. no manual.. how do I change the co2 cartridge?
Are you sure it's a crosman? My Walther PPK is made by a company named Umarex USA. They make copies of most popular handguns. I downloaded the manual at www.umarexusa.com/Pages/Manuals.aspx
You'll have to create an account to download it.
Apr 30, 2011 | Sport & Outdoor - Others
I have a walther bb gun, need to find parts..
HI. YOUR BB GUN HAS NO FIRING PIN,,IT USES A SMALL TYPE OF RELEASE TO LET THE SPRING GO IF THAT IS THE TYPE OF BB GUN YOU HAVE. IF ITS THE (CO2) TYPE IT RUNS A LITTLE DIFFERENT BUT NO FIRING PIN. I HOPE THIS HELPS. JIMBO
Aug 15, 2009 | Sport & Outdoor - Others
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Air rifle?
Most rifles will hit whithin at least one inch across a normal back yard. You're quality is going to come from the manufacturer. CO2 and Air Pump is a personal choice, I have noticed no difference in performance, though some say CO2 is more reliable. Daisy is a classic manufacturer and has some modern, good weighted rifles that will shoot dependably. Anything with a Walther barrel or the Walther name is a good investment when it comes to rifles (not so much for pistols). Break barrel actions are prone to jam, be difficult to open once lead shavings build up, and pinch nastilly, and if you have a child or are a novice shooter yourself, a traditional action will help you learn proper habits early on. You really shouldnt spend 300$ for an Air Rifle, or even 200...Maybe even 100.
Mar 25, 2009 | Caliber Gamo USA Hunter Elite .177 Air...
Grilling Logo
66 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
