Question about Garden
I need a finial for a Sonoma 9' crank & tilt umbrella
How can I fix the rip on my patio umbrella
why bother, most of them are made in China and like most stuff we are a throw away society, it will cost you plenty for glue and material if you still chose to fix it, The most I get frmo umbrellas int eh desert sun is barely a year.
May 31, 2015 | SONOMA outdoors Crank And Tilt Solar Led...
These are to prevent the umbrella from flapping in the wind when it is down. When you lower the umbrella, simply wrap the velcro strap around the entire circumference of the lowered umbrella, then attach it to the other tab. That's it!
May 11, 2015 | Hampton Bay Patio Umbrella. 11 ft. dia....
The plastc crank insets for the crank handle is striped as it is plastic. Where do I get another one?
The same thing happened with ours within the first year. Were you able to find a part to fix it?
Jun 01, 2014 | SONOMA outdoors Lighted Patio Umbrella
Patio umbrella
Usually a inner cable problem, most umbrellas use a plastic coated nylon cable, I swapped mine for a 1,5mm steel wire, no problems since, take the screws out of the handle and check it is connected.
May 21, 2014 | Garden
Towa umbrellas parts
Can you post picture or video of it?
May 29, 2013 | Computers & Internet
I have a crank style patio umbrella that won't stay up when we try to crank it up. How do I fix this? You crank it up and it just rolls back down when you let go of the crank.
We had the same problem. We simply used a bungee type cord to hold the crank handle in place once the umbrella had been opened.
Jun 26, 2011 | Garden
Patio umbrella tilt locking hinge broke
Need a fix for my patio umbrella the wind snpped the push button tilt mechanism.
Mar 31, 2009 | Garden
97 GMC Sonoma
checked fuses , #9 fuse for fuel pump was loose.
Jun 21, 2008 | 1997 GMC Sonoma
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
