Question about Bayliner Boating
1969 BAYLINER BOAT 30'CABIN CRUSIER HOW TO WIRE IGNITION
  • 5687 Answers
SOURCE: What engine should fit my 28´bayliner boat
Yes there is. Saw one at a boat show and I believe it was also Swedish. You may want to look for used replacements on the web. I do not know where you live, but there are boats on the Great lakes with low hours because of the short boating season. There are also victims of hurricanes with good engines down South.
Posted on Jun 18, 2009
  • 15 Answers
SOURCE: We have a brand new Bayliner 210. Our boat battery
Yes, the GPS will consume a slight amount of power even when powered off. Most people call this "pulse-power" in the electrical industry. Also, as an example at home, if you have a cell-phone charger plugged into the wall, but do Not have the cell-phone plugged-in and charging - the power adapter still drains a very small amount of power and does in-fact use electricity just because it is plugged-in. On a 21-foot Bayliner, I recommend installing a Battery-Saver at the point of the battery, which automatically cuts all power to the battery when it reaches a certain low-level. Then when you need to start the boat - you press one button on the Battery Saver - and it gives you enough power to start the boat and enjoy your water experience. I also might recommend swinging by an auto-shop that has a rolling-battery-tester just to be sure you battery is still good. Even a brand new battery can be defective at day-one or months later. Have a qualified person test the battery to see if it is holding a charge correctly (while the GPS is ON and while it is Off.) The results will tell you the true story.
Posted on Aug 16, 2009
Testimonial: "Thank you that was very helpful! We also discovered the off switch on this unit is also a dimmer switch. We could not see in daylight it was still on."
  • 5687 Answers
SOURCE: hydraulic going low only, not lifting up in my bayliner boat
If this is an inboard/outboard you have 2 relays for the outdrive. One is for UP and the other is for Down. If this is an outboard you may only have 1 relay.
You need to work with what is there to diagnose the problem. The down relay is working. It has a wire that goes to the pump on the transom. The UP relay also has a wire that goes to the pump. Disconnect the working wire from the Down relay and put the wire from the UP relay (to the pump on the transom) in its place.
Switch up/down wires if this is an outboard.
This will make the Down relay work the pump in the opposite direction. If the pump itself does not work both ways the pump is bad. If the outdrive now goes UP the pump is good.
Most likely the UP relay is bad. But there is a Tickler wire on each relay to make the Relays work. Check for Voltage at the Tickler wire-when you press the Trim button for UP position. If you have power at the Tickler the Relay is bad if it does not respond.
Make sure you get the proper replacement part. Most Relays are Negative ground. But boats can use Isolated relays which do not ground through the case.
This second type of Relay may have the same number of terminals but internally it is different.
I also have a Bayliner with the OMC King Cobra in it and had to work on my relays too.
Posted on Apr 11, 2010
bigguy810
  • 448 Answers
SOURCE: how do I remove the starter from a 3.0l cobra
cobra is telling me ford so if you are looking at the motor
the starter is on the left side under the exhaust manifold
it will have 3 1/2 in bolts holding it in make sure you un
hook the battery before removing the starter ///
the battery wire on the starter is a 5/8 or 11/16
wrench// that's all you need to remove the starter
i hope this helps you
bob
Posted on Jun 06, 2011
goldbill
  • 184 Answers
SOURCE: 89 bayliner capri 17' inboard/outboard will not go in reverse
Should first have some one look at the shift in the engine compartment while some one runs it from the control box. If no movement, would be the cable.
Then undo the bottom drain plug and see if the oil is full of metal shavings. Yikes
Last see if the shifter going to the lower is actually moving when you shift.
Posted on Nov 29, 2012
I need dimensions for a 21' Bayliner Trophy
Most of those models are 21'... makes no difference if measured front to back or vice versa.
Aug 16, 2017 | Taylormade Bayliner Custom Boat Cover -...
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
Have a 2001 bayloner throphey how much fuel it holds
Are you sure you don't have a 2001 Bayliner Trophy? ;>)
7 gallons, but they come in sizes 17 feet to 31 feet and 125HP to 225HP.
2001 Bayliner Trophy Asking Price: $13,999 OR BEST OFFER Condition: Good. Description Location: Ridgewood, New York Seller's Notes: AWESOME BOAT!! Body Style: Power Boat Length: 21 Hull: FIBERGLASS Class: FISH/SKI BOAT Engine: 2010 Hyundai 150 # Engines: one Fuel Capacity: seven gallons Horsepower: 150 VIN: Request the VIN Seller's Comments Great boat, Lots of storage, 270 hours on motor, Well maintained, Reliable, Great for the lake, Depth/Fish/GPS System, Well equipped, Live well, Pump, Anchor, Seats four, Lots of cabin room, Equipped with toilet.
Easiest way is to run it dry with a 1 gallon portable can on board. Stay close to the marina until main tank runs out, top up with the gallon can, and then go to the marina and fill it up. Whatever it takes minus 1 gallon is the capacity. Then refill that gallon can and log how many miles you do on a full tank. I carry 2 x 6 gallon tanks, I know one tank will take my 95 kilometres (I am in Canada)
Red portable fuel marine tanks hold 6 gallons. The size is marked on it. If you have a fixed tank, they are usually 20 gallons, but to be sure use my method and a fill.
Bayliner Trophy 2002
May 14, 2016 | Cars & Trucks
How do you remove a gas tank from a Bayliner indoor/outdoor boat
I did not know Byliner made indoor boats. If you are referring to an I/O engine boat, it is usually under the floor, along side the engine, etc. Screws and cutting sealant is usually involved. It can be a real bear. Ask a Pro.
Mar 19, 2015 | Boating
Where can I get a service manual for 3.0 Bayliner 4 cylinder boat
possibly from bayliner or the motor manufacturer.
Aug 18, 2014 | Boating
Hydraulic going low only, not lifting up in my bayliner boat
Apr 07, 2010 | Boating
I need wiring diagram for boat 1993 Bayliner jazz engine: mercury 90 hp 3 cylinder 2 stroke jet serial no:oeo31008
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
Sep 24, 2009 | Boating
Jun 18, 2009 | Boating
Boating Logo
46 people viewed this question
Top Bayliner Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Bayliner Boating Expert? Answer questions, earn points and help others
