Question about Garden
Cub Cadet. Engine starts and runs but stops running after several minutes. I changed fuel filter and fuel pump also replaced battery but. Did not solve problem
    Top Expert:
  • Garden Master
  • 50,496 Answers
Pull and rebuild the carby
check for fuel flow through the fuel tap
Posted on Apr 26, 2017
Cub cadet rzt 50 with kohler engine runs a few minutes and shuts off
sounds fuel related. check the fuel lines and filter be sure they are good. if you unhook the fuel line at the carburetor and let it run out into a bucket for a few minutes, it should have a steady stream of flow. if it slows down or stops loosen the fuel cap. if it starts back to a good flow. replace the fuel cap. that may be causing the problem. be sure the vacuum tube for the fuel pump isnt cracked or hard.
Apr 04, 2018 | Cub Cadet Garden
My cub cadet modle LT1045 doesn't seem to be getting gas. The fuel filter looks clean. If I spray gas directly into the carb it runs fine but as soon as I stop it dies.
Confirm that the choke is closing completely., Check that the fuel pick up hose does not have a air leak. Confirm that the vent hole in fuel cap is not plugged.(common problem)
Remove fuel line hose to carburetor catching fuel output in a suitable container crank engine and confirm fuel pump is working.
Remove fuel bowl and confirm needle valve is not stuck closed.
Hope this helps?
Fuel Pump
Needle stuck closed
ca4f54cab4d4c1bb583599b331fd2337--small-engine-repair-lawn-mower-repair-u3ralalmkh2yk13xn5gn3lpt-2-2.jpg Check fuel filter
Check vacuum line connection for leaks.
Jul 01, 2017 | Cub Cadet Garden
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I have a cub cadet with 16hp kohler, I changed the fuel line because it was leaking, since then, it will only run for twenty minutes while mowing. I have replaced the fuel pump,filter and had the carb
take a look inside the tank and see if a piece of the old hose is floating around then try it with the gas cap loose the vent could be plugged
Jul 08, 2012 | Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet tank stops running 5-20 minuts after i start mowing but will run on full choke, have taken carb apart and cleaned well , bypassed fuel filter, cleaned air filter, checked plug , changed fuel...
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Apr 28, 2010 | Cub Cadet Street Sign- tractor lawn riding...
MY PUSHMOWER WILL START AND STOP AFTER ONE MINUTE
An engine that will start, but will only run for a short period of time will often have one of the following causes:
*Defective or inoperative choke or primer.
* Water or dirt contamination in fuel system.
* Broken, cracked, or clogged fuel lines.
* A dirty fuel filter
* A carburator out of adjustment.
If this usually happens during cold starts, then you may have a situation where the primer or choke is not working properly.
Check the cap on the fuel tank and make sure that it is vented properly.
I sure hope this helps you and good luck.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
