Question about Garden
Air gap between coil and flywheel on 088 sthill saw
    Problem Solver:
  • 20 Answers
ABOUT .20 TO .30 THOUS
Posted on Apr 26, 2017
Can you please tell me the air gap between coil and flywheel on a sthill chain saw and flywheel nut size thanks
Use a flexible feeler gauge to measure the gap. The magneto gap for any 2-cycle engine chain saw should 12-18 thousands of an inch. The gap is much less important than simply NOT HITTING the coil frame at any point on the flywheel. The nut is probably metric but I cannot tell you what size it should be. BE CAREFUL! Some chain saws have LEFT HANDED THREADS on such shafts! But you can usually tell by studying the protruding threads at the nut ... if there are any!
Apr 26, 2017 | Garden
Air gap for coil
Assume you are asking for the air gap between the flywheel and the ignition coil?
Obtaining the correct gap from the manufacturer's specifications is best because although in theory a close gap is desirable for efficiency, flywheels grow as the engine heats up and a large flywheel can grow quite a lot.
Brass feeler gauges are best for setting air gaps as they are none-magnetic. A typical air gap would be in the region of 10 to 14 thou.
Mar 16, 2016 | Garden
Coil test/gap on
Around 30 thou. Move the flywheel around until it is opposite the coil legs and place a single thickness piece of cigarette packet cardboard between the legs of the coil and the magnet on the flywheel. Tighten the coil and that is pretty much as near as is required. Obviously remove the cardboard afterwards. I have never known a saw in the 40 years I have been repairing them, which would not work perfectly with that air gap.
Feb 17, 2015 | Garden
Start makita dpc7331
Change out the coil. But check to see that the wire going from the coil to the switch is not grounded out prior to the switch. Turn switch in off position and have coil unplugged to test for continuity should be none. Flip switch to run and you should have continuity now. EBay $135.00 + shipping for a coil. Get yourself a T27 long reach screw driver for the bolts needed to take off. remove air filter and housing. remove starter recoil. remove sparkplug wire. cover around sparkplug 3 T27 screws 2 tward the carb side and 1 on the flywheel; side toward muffler, then lift off. coil 2 screws and wire for grounding the coil(stop the saw) has a spade connector disconnect. replace coil and put back together in reverse. Oh by the way you should have a pretty strong magnet in the flywheel if not your have to purchase a flywheel too or re-induce magnetism to it. Coil to flywheel Gap
? aprox .020 gap should work its about the standad for all 2 strokes but you will need brass feeler gauges because you set it at the magnet on the flywheel to the iron part of the coil sticking out of the plastic coil case.
Aug 29, 2013 | Makita Tools & Hardware - Others
I'd like to know what steps to take to replace the contact points on a 1978 Poulan Micro XXV Super Deluxe 14" chain saw
Its a long time since i saw one of these, however, start by removing the starter cover screws and the starter itself, you need to remove the flywheel nut,1/2 spanner as far as i remember, strike the non magnet side of the flywheel with a suitable hammer, the flywheel should just pop off, remove the points back plate cover, this should just pull off, the points and condensor are all one peice, held with two screws, either clean the points or replace the assembly, the back plate will have slots to allow you to set the points gap, the gap is between 12 and 15 thousands of an inch, put a small amount of grease on the felt pad against the cam, refit the flywheel and nut, take care to re fit it onto the woodruff key properly, the air gap between the coil and the flywheel should be set at approx 0.5mm, re fit the starter and check for a spark.
Apr 02, 2011 | Poulan 14" Chainsaw
16'' chain Saw wont fire
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Garden
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Coil gap
Remove the plug. Place a business or index card between the coil and flywheel. Rotate the flywheel until the magnet holds the coil tightly against the card, tighten all fasteners. Rotate the flywheel until the magnetic attraction eases and remove the card. Rotate the flywheel through a couple of revolutions and ensure nothing drags or contacts the flywheel. HTH
Lou
Nov 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
