Question about Garden
Can you please tell me the air gap between the fly wheel and coil is on 088sthillsaw
    Top Expert:
  • Garden Master
  • 49,277 Answers
As close as possible with out touching the flywheel
the closer the stronger the spark
.002-.005"
Posted on Apr 26, 2017
What iscoil gap on gx160 honda5.5
Call a small equipment dealer & ask
for the specs
Jul 14, 2014 | Honda Quincy 17 - Gallon Air Compressor...
What is the gap for coil on a21 hp briggs
Normal air gap is .010 and if the coil is good the air gap in not that fussy i had them as far as .030 but do not let it rub on the fly wheel
May 04, 2014 | Briggs & Stratton Garden
No spark from coil to plugcub cadet coil
magnets might not be good in fly wheel or coil no good check gap on coil to fly wheel and spark plug gap
Sep 14, 2013 | Garden
No spark
The spark generator that sits close to the fly wheel only needs a mm gap. Make sure that this is the case. If there is a small gap there is possibly a break in the wire or the points under the fly wheel may also be rusty.
Jun 29, 2013 | Garden
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Aug 06, 2010 | Echo Garden
Model TB320BV 2-cycle blower.
there is no set gap realy what i do is put a thin bit of carbord inbetween the coil and fly wheel so there is say 25th of an inch of gap dont set it so tight that the fly wheel hit's the coil or it will distroy it there needs to be a very small gap and it will work just fine,,ok?
Jul 27, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
This engine is an old 8horse on a snowblower. it has no spark and the plug is good. so is the coil bad and is the coil the piece that sits above fly wheel,and does the fly wheel need to come off to connect...
doesn't mean coil is bad, may just need points and condensor. They get old and wear, old b/s part no. 299061 , these are under flywheel , and points cover. either replace points and condensor or try cleaning them with flex file.(temp. repair) points gap is .020. not sure of air gap of coil to flywheel. coil can be tested at most shops, You will be able to see if points are burnt visually. hope this helps.
Jan 13, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
