Question about Garden
3245c John deer rear mower deck do not run
Front mower run or cut but rear do not run or cut
  • 143 Answers
SOURCE: Have a John Deere L108 will run but stalls out
This sounds like the grassbox switch.Get someone to press down on the box at the back and see if it works, if it will you will have to adjust the switch.
Posted on May 15, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
SOURCE: i need to run the mower deck belt on my john deere...
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
Posted on May 25, 2010
SOURCE: John Deere ride on mower L100 17 hp.
my ride on runs well for 5 miutes then just stops wait a few minutes starts right up but does this over and over some help please
Posted on Jun 23, 2010
  • 7 Answers
SOURCE: I need a belt routing diagram for a John Deere
If you go to this page http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO , scroll down the left side to the heading for your deck.
Posted on Aug 22, 2010
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
How to level the cut hight of a L130 Jphn Deere Lawn mower
Inflate all tires to the proper air pressure using a high quality gauge such as a digital, not the $3.00 ones but a good quality from say Napa. Make sure the tires are within the same wear of tread and inflated to + - 1/2 PSI of the proper pressure. Find a nice clean and flat surface to park and using a "Tee" square check the left and right rear "corners" of the deck. If you do not own a "Tee" square I've used large wood wedges that taper from 0" to 3" (such as a wedge made from a 2X4), slide the wedge until the tapered part just touches the rear corners of the deck and mark it with a pencil, do the same on the other side and then adjust the rear hangers until the deck is level within 1/8" or less side to side. Then adjust the front hanger to set the front of the deck 1/8" lower than the rear and you are there. From then on simply keep the tires inflated using the example above and your deck should go right back to level again.
If the out of level cut still persists check to ensure the blade tips are even with each other, one blade higher than the other could be a bend blade or a distorted deck and possibly a bad spindle bearing.
Aug 02, 2014 | John Deere Garden
42" deck the dicharge side
First thing to check would be the tire pressure. I usually run 12 psi in the front and 10 psi in the rear. Next would be to check the deck bearings. If the bearings are bad in either spindle the blade will cut uneven. Easiest way to check bearings is to grab ahold of the blade and try to rock side to side. If all is ok there the deck will need to be leveled. John Deere makes a blade leveler which can be picked up at the local dealer for a few bucks. Let me know if you have any other questions or if this helps, Daniel.
Sep 05, 2011 | John Deere 22HP VTwin 48" Riding Mower
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
