Question about Kenmore Washing Machines
Oil leak on my kenmore series 70 washer
Not spinning and oil all over the bottom
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver
Posted on Apr 27, 2007
  • 290 Answers
SOURCE: Kenmore 70 Series Washer
Most likely you need to replace the lid switch.
Open the lid and make sure the actuator that pushes the switch is still attached to the lid. Use a pen or screwdriver to depress the switch through the hole in the top of the cabinet, you should hear a click as the switch closes. I usually find that the switch has actually broken off from the cabinet and is hanging loose in the machine.
To replace the switch
Remove the screws that hold the console to the cabinet. Flip the console up and back like opening a car hood. unplug the wire connector for the lid switch. Pop out the two clips that hold the cabinet to the rear panel of the washer. The cabinet will tilt forward and slide off the machine base. You can now replace the switch from inside the cabinet.
If you need further help, please post the complete model number from the washer so I can see exactly how your washer is set up.
Posted on Apr 12, 2008
  • 113 Answers
SOURCE: kenmore 70 series washer
Sounds like a broken lid switch. Easy to fix. Heres a schematic.Its # 11. Try part # 285671. Dave
Posted on Dec 16, 2008
  • 370 Answers
SOURCE: Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Posted on Feb 13, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Apr 26, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Open Questions:
Washing Machines Logo
Sal De
 Brian Main
Brian Main
