Question about Sanyo Televison & Video
Remote code for dish network for Sanyo mod# FW32D25T bought at Walmart.
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Posted on Feb 14, 2009
  • 374 Answers
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Posted on May 25, 2009
SOURCE: RCA L32HD31R/Dish Network Remote Code Problem
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
Posted on Aug 21, 2009
SOURCE: whad code do i hse to control my sanyo dp19649 tv
Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
Posted on Sep 08, 2009
SOURCE: I need a dish network remote control code for an ESA television.
try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
Posted on Feb 13, 2010
Dish remote code for Sanyo FW32D25T
there are some variables. but this link should help How to Program Remote to TV or Other Device MyDISH DISH Customer Support
Apr 26, 2017 | Sanyo Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Just bought a Sanyo DS27800 27" TV but no remote any help where to get one or replacent remote that will work with this tv.thanks
any big box store or radio shack should have a suitable replacement. your cable or directv or dish remote can be programmed for the tv depending on which provider you have. go to the website of which one you have and go to "remote codes" section if you dont have cable or dish then go to walmart and get a universal. the more you pay, the more features you will get. look closely at the packaging. thrift stores usually have a whole wall of old remotes in bags you can start looking there too. if you can find a sanyo vcr it may have some tv functions that might have the tv codes on it.
Dec 08, 2010 | Sanyo DS27800 27" TV
I need the code for my remote for a sanyo tv
DISH Network Codes
Sanyo 542, 589, 590, 591, 592,
Sep 03, 2010 | DISH Network IR Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Need Sanyo TV code numbers
May 22, 2009 | DISH Network IR Remote Control
Remote code for Akai 37" lcd with Dish Network
I have a akai 42" plasma and went to walmart and bought a Phillips Universal remote SRU3004WM/17 for @$14.95 and it works both my Akai and Dish network.......
Jul 17, 2008 | Akai LCT3201TD 32 in. LCD Television
Sanyo FXRG Remote
Have a dish network box. ( EDGESTAR) and my remote broke. i am trying to get the code to program the AUX button to work for the dish. on my Sanyo FXRG remote. please help me!
Apr 20, 2008 | Sanyo DS27510 27" TV
Need codes for a Sanyo TV
I have a 15-2147. The codes from solution 1 didn't work for my remote, so I used the codes listed on Radio Shack's page for the 15-2142. The first code worked. Those codes are: 0154, 1907
Aug 17, 2007 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
49 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
