Question about The Office Equipment & Supplies
My richo photocopy machine 2018d does not work any longer from the ADF. It doesn't pick paper from the ADF again, the alert that normally sound from the ADF when you insert paper does not sound again
SOURCE: Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Posted on Sep 19, 2008
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Posted on Dec 03, 2008
  • 19 Answers
SOURCE: Richo Aficio 450e photocopy machine (Error Code SC360)
Replace HDD
Posted on Dec 24, 2008
  • 8 Answers
SOURCE: HP Officejet Pro L7580 ADF will not pick up paper
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
How to reset paper tray in Richo Aficio 2045e photocopier
Verify the paper blocated under tray or the paper tray actuators.
Jan 04, 2012 | Office Equipment & Supplies
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Solve my problum
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
23 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
AUT_COM
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
