Question about Golf
Have a 1991 gas club golf cart. It was running fine and then just stopped like someone turned of a switch. Has spark, and plug is wet so must be getting fuel. Allen
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
  • 85 Answers
SOURCE: I just bought new batteries for my Club Cart Golf
You have the motor hooked up in reverse, you need to switch the two wires leading to the motor in order to fix it.
Posted on Oct 04, 2009
  • 100 Answers
SOURCE: I replaced the fwd / rev switch on my Club Car 1985
I recently replaced a F/R switch and just happened to write down which wires went where so maybe I can help. The front switch ( closest to front of cart) green/white wire to top contact, white/black to bottom.
Middle switch red/white to top, orange to bottom.
Rear switch green to top, black to middle and white to bottom.
Posted on Nov 08, 2009
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
johndoe541
  • 784 Answers
SOURCE: echo cs-370 chainsaw wont start.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Posted on Mar 17, 2011
I have a 1994 club car golf cart , backfires , ******* gas , spark plug gets black with what do you think I should do to rectify my problem , thank you , roger
You may have a weak spark or overly rich fuel mixture; your mixture should be 32:1 doing break-in period and then normally 128:1 if you running a richer (more oil) your engine will run lean and be hot thus the spark plug will be dark/black and if running too hot will melt the electrodes or burn a hole in the piston.
Sep 20, 2017 | Golf
We have a 1999 gas club car golf cart just replaced the ignition coil. It now won't turn off
You need to run a wire to the coil from the hot wire coming from your key/ignition switch. This will ground the coil and eliminate the spark.
Sep 02, 2016 | Golf
I'm not getting any spark out of the plug to start the club cart(1994)
Is this a golf cart? Single plug? Test for current getting to coil when ignition switched to ON. If yes, either bad ignition module or bad coil. If NO, check ignition switch and related wiring.
May 11, 2016 | Cars & Trucks
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
How come my cart only runs about 15 minutes after changing?
it helps to know what make and model and year we are dealing with but this is fairly easy unless it is electrical if it is gas for instance a yamaha 1985 G1 golf cart like we own the starter/generator was bad and eventually it will no longer start at all. replace this and it should be fine first we thought it was the battery but after replacing that it still caused us issues so we knew next step was the battery wasnt getting enough charge so replaced start/generator. but like i said it depends on make year and model and if it is gas or electric. it can also be a relay switch. I also had a lawn mower that would run and shut off soon after starting and that turned out to be watery gas.. there are always 3 elements 1. spark 2. gas or 3. compression . that are involved in starting and you have to narrow down most often it is spark most people find that replacing the spark plugs usually gets them through each summer but if you have bad gas that can cause problems the least likely is the compression but if it is an old cart or was not taken care of then that can also cause issues. use this chart in the future to help resolve start issues it helps me many times . I hope this helps. 25338104-ft35htv4rkd0kmp4yjrdzdf5-2-0.gif
Dec 26, 2014 | Golf
Club car golf cart lights
Wiring, fuse and switch. Check for voltage at switch first, if none, check for a fuse in the circuit. I would suspect a fuse or faulty switch first.
Aug 20, 2014 | Golf
Club car golf cart
Electric or gas
Oct 22, 2013 | Golf
I have a 1988 club car gas golf cart. I have done everything that I can think off. cleaned carburater, drained all fuel tank, replaced battery, replaced some of the gas lines. golf cart will only run...
When you say cleaned carburater did you take it all apart and spray carb cleaner through all the ports, it only takes the smallest debris for it to not run properly
Sep 07, 2017 | Cars & Trucks
Golf Logo
253 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
