How many points do I have - Computers & Internet
I have a 1993 ford Econovan maxi . I have ignition point . What is the gap on the ignition point . Thanks
point gap is .40 to .50 mm ( point 4 to point 5 mm) or .015 to .20"
most point distributors are at the .02 " mark but check and adjust as points to wide will misfire under load or lack power if too close
point gap variations can change ignition timing
Nov 20, 2016 | Ford Cars & Trucks
I have a allis chalmers 1950 wd,can the points short out on the distributer
the short can be from the insulator in the pivot point allowing that point to touch the fixed point base
other problems are that the wear block on the moving point wears right down allowing the metal tab to touch on the cam block
the small copper pig tail for the points base plate breaks and there is no ground for the point action and the condenser tag touches the stud on which the coil wire is attached to the base of the points
a simple test of points is to turn on the ignition , turn the engine slowly over until the points close, then use an object ( flat bladed screw driver and push on the moving point to break the circuit
you should get a spark at the points or a zap noise each time you break the points circuit
as it is a common distributor and you check around , it is very possible that you could replace the points with an electronic system or pointless ignition
Sep 19, 2016 | Garden
1953 farmall super a tractor having points issue. Getting spark to coil and leaving coil. Also getting fire to distrubitor and point but none from point to contact. New points and condenser. It is a 6 volt...
Check for a small braided copper wire that is attached to the point plate to the body of the distributor, Check that the wire terminal to the point is in fact not shorting out as ther should be a stepped fibre washer between the wire and the point base as there can be no contact until the power gets to the movable point. Check that the movable point is not touching the point base
Mar 03, 2013 | Garden
What are redeemable points ? what can i get with the points i have earned ?
Reedemable Points. Redeemable points are all points you have earned on FixYa by solving problems minus the points you have spent on shop purchases. For example: If you've earned 3,000 points on FixYa and then purchase a t-shirt worth 2,500 points, you will have 500 redeemable points left to spend.
Dec 30, 2012 | FixYa Service
Adjusting the points
With points cover off,slowly bring engine to the highest point on the points cam.Its easiest to do this with the spark plug out,and slowly spin the engine with the kick start. Once you get it to the highest point on the points cam,the points should be "open". Insert feeler gauges untill you find the correct one...(it should have slight resistance). The check what the recommended gap is for that model. After finding the recomended gap,use the feeler gauge that matches the recomended gap,and isert between the points. There should be two screws,one on each end of the points. Loosen those two screws,and the body of the point will move,one way to "open": the gap,the other to "close" the gap. With feeler gauge between the points contact,close untill you feel slight resistance when moving the gauge back and forth,and tighten the set screws on the points body.
Aug 31, 2012 | 1973 Honda CB 100
Getting free xbox live ms points
There is no good way to get a lot of Microsoft Points for free. However, if you sign up for Bing Rewards, you can get 100 Microsoft Points for 125 points and 400 Microsoft Points for 425 points. You can also redeem those points for other things, like free Starbucks or entering for free stuff.
Hope that helps. Good Luck!!!
Jun 23, 2012 | Microsoft XBOX 360 Live Points 4000
Any cheats for rapala tournament fishing
  • Bonus lures and videosAnswer all questions correctly under the "Quiz" section to unlock bonus lures and videos.
  • Quiz answersThe following is a list of all answers (in order) for the "Quiz" section:
      1. B2. C3. D4. D5. C6. B7. D8. D9. C10. B11. B12. A13. B14. D15. B16. D17. B18. D19. C20. B21. D22. A23. B24. B25. C26. B27. D28. A29. C30. C31. B32. C33. B34. C35. C36. B37. A38. D39. B40. C41. C42. A43. B44. B45. C
  • AchievementsAccomplish the indicated achievement to get the corresponding number of Gamerscore points:
      Tournament Completion (50 points): Finish the Tournament game mode.Tournament Master (40 points): Finish the Tournament game mode in first place (Gold Medal).Rapala Series (25 points): Finish the Rapala Series event.American Tour (25 points): Finish the American Tour event.Lund Series (25 points): Finish the Lund Series event.Elite Tour (25 points): Finish the Elite Tour event.Ranger Tour (25 points): Finish the Ranger Tour event.Legends Series (25 points): Finish the Legends Tour event.Rapala Pro Tournament (25 points): Finish the Rapala Pro Tournament event.Time Challenge Completion (50 points): Finish the Time Challenge game mode.Arcade Challenge Completion (50 points): Finish the Arcade Challenge game mode.Bass Champion (20 points): Catch 40 Bass.Perch Champion (20 points): Catch 40 Perch.Trout Champion (20 points): Catch 40 Trout.Catfish Champion (20 points): Catch 40 Catfish.Salmon King (20 points): Catch 20 King Salmon.Fish Master (25 points): Catch every fish in the game at least once.Fishing Boat Expert (20 points): Use all boats at least once in a tournament event.Shore Fishing Expert (20 points): Catch at least 15 different fish species casting only from the shores.Master of Deceivement (135 points): Finish the Tournament game mode with every character in the game at least once.Fishing Rod Expert (25 points): Catch at least 20 fish using every rod in the game.Fishing Reel Expert (25 points): Catch at least 20 fish using every reel in the game.Fishing Line Expert (25 points): Catch at least 20 fish using every fishing line in the game.Lure Master (75 points): Use each lure at least 10 times.Lure Apprentice (25 points): Catch at least 10 Lake Sturgeon using a single lure type.Lure Expert (25 points): Catch at least 30 Chain Pickerel using a single lure type.Lure Specialist (50 points): Catch at least 60 King Salmon using a single lure type.Always Ready (25 points): Catch your first fish within the first 2 minutes of entering a new tournament fishing day.Quick Fishing (40 points): Catch your first 3 fish in a new tournament fishing day in less then 6 minutes.Bad Weather (20 points): Catch at least 40 fish while in bad weather.
  • Sep 28, 2009 | Nintendo Wii Console
    Manual focus points 40D
    Try checking C.Fn III, 3: AF point selection method. Yours might still be on option 2.
    0: Normal - Works by pressing the AF Point button and then the Multi-controller.
    1: Multi-controller direct - Press the multi-controller to directly select an AF point (without first having to press the AF Point button). Pressing the AF button reinstates all AF points for auto AF point selection.
    2: Quick Control Dial direct - turn the Quick Control Dial to select AF points. In this mode, AF points will not be displayed on the LCD panel.
    Jul 18, 2008 | Canon EOS 40D Digital Camera
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
