Question about RCA Audio Players & Recorders
How do I connect rca headphones #whp141 to my LG tv model #47LM6200..Have audio-out plug, but when I plug in the headset I only get "buzzing"..HELP
odiebugs
  • 949 Answers
SOURCE: RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Posted on Mar 27, 2009
SOURCE: RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Posted on May 30, 2009
SOURCE: No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Posted on Feb 04, 2010
Testimonial: "Thank you for the response - will try this and see if it works"
SOURCE: Have Sony infrared stereo transmitter
Download this headphone manual->
http://www.mgmi.fr/docs/pdfprod/MDMDR-IF140K.pdf
Note:PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
Posted on Jun 10, 2011
SOURCE: just bought the brookstone wireless tv headphones.
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
Posted on Dec 28, 2011
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Hdtv optical audio output works except in tv mode
Unplug one of the RCA plugs one at a time, see if sound changes to no buzz but one ear channel only. The buzz can occur when RCA is not connected correctly and the video feed is put onto the earth wire of both audio feeds.
Dec 15, 2013 | LG Televison & Video
Need service phone # RCA wireless headphones WHP141 PLEASE HELP THANK YOU
All RCA Television Support Numbers hours of operation are 9 AM - 9 PM Monday - Friday EST and 10 AM - 7 PM EST on weekends. bullet_2by2.gifRCA Audio / Video Product Support: 800-433-7316
bullet_2by2.gifRCA Digital Audio Product Support: 866-449-7112
bullet_2by2.gifRCA Clock Radios and Camcorders Product Support: 800-645-4994
bullet_2by2.gifRCA DVD Product Support: 866-444-6478
bullet_2by2.gifRCA Accessory Product Support: 800-264-8854
bullet_2by2.gifRCA Telephone Product Support: 800-511-3180
bullet_2by2.gifRCA MSNTV Product Support: 800-722-9599
bullet_2by2.gifRCA DRC8335 Product Support: 877-805-0519
Apr 05, 2011 | RCA WHP141 Consumer Headphones
Exactly which audio port do I plug the RCA WHP141 charger stand into for TV watching?
The headphones one - the small 3.5 jack one, the same as the one on your mp3 player.
Jul 23, 2010 | RCA WHP141 Consumer Headphones
My rca whp141 doesn't seem to work with my Sony 32 Bravia Kdl32L4000. Can't get the light to light up on the base unit.help Please
Press the menu button from the remote, look for "Settings". You should have a "Sound" category. Once you've located that, press Enter to go into the submenu. You want to look for "Audio Out" option and change it from the default "Variable" to "Fixed". Then you should have sound in your headphone. You can just either mute or lower the volume of your TV. Hope this help.
Jun 30, 2010 | RCA WHP141 Consumer Headphones
The jack will not fit in my tv
There are lots of different sized jack plug adapters on the market, you should be able to find one to do the job. I would try Amazon first, they have a good range and decent pictures of products.
Feb 11, 2010 | RCA WHP141 Consumer Headphones
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Hope this helps.
Jan 08, 2008 | RCA WHP141 Consumer Headphones
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
