Question about Technics Audio Players & Recorders
Where can I find a motor belt for technics cd changer sl-mc4 - in la mesa ca or el cajon ca.
fire sine
  • 382 Answers
SOURCE: technic turntable SL-101
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
These guys are pros.
Posted on Nov 08, 2007
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
mrgreenz
  • 962 Answers
SOURCE: Mazda 626 a?o 2001, no enciende el motor.
Que code le dieron quando probaron la computadora ? PO..? mire aver si tiene lumbre en las plugas de sparke. Quite una de las plogas y pongala contra un ground de metal. lleve a alguien que le de vuelta a engenio. debe de tener una lumbre fuerte. Si no, puede ser que algo que ver con el coil o algun sensor. .
Posted on Nov 26, 2008
djproaudio
  • 515 Answers
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Posted on Dec 18, 2008
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
Door won't open on my Technics SL- MC4 60+1 CD player
check the belt that moves the door and tiny leaf switch
Nov 30, 2016 | Technics SL-MC4 61-Disc CD Changer
Our Technics cd Disc Changer SL-MC4 is unable to shut off and constantly search for disc.
take the top cover off and make sure the drive belt on the top of the cd mechanism is not loose or off.
Nov 14, 2016 | Technics Audio Players & Recorders
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Missing remote for Technicis Model SL-MC59 Cd changer
You will need to go online to Technics and contact customer support and the technical department to see if they can help.
Apr 05, 2012 | Technics SL-MC4 61-Disc CD Changer
No instructions how do i open to load discs
To open the front panel you just pull it gently on both sides - it is hinged on the bottom. Detailed instructions can be found in the manual which you can download here: SL-MC4 Manual
May 05, 2011 | Technics SL-MC4 61-Disc CD Changer
How do I play full random mode
the feature you are looking for is titled shuffle. it should come up in the menu
Nov 19, 2008 | Technics SL-MC4 61-Disc CD Changer
Remote controle
Unfortunately, the remote for this unit has been discontinued and is no longer available from the Pansonic (the parent company of Technics). However, here is the model number, just in case you might be able to find it from a retailer who might have a few left in stock: EUR645270 - just type in this number in google, and you'll get some results which may or may not help you.
Aug 14, 2007 | Technics SL-MC4 61-Disc CD Changer
27 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
