Question about Garden
How to aline the timing marks on a fuel injector pump on a 250as Belarus tractor
2 Suggested Answers
  • 2468 Answers
SOURCE: ran tractor out of fuel try prime got fuel to pump
you need to open the fuel line at the injector on the cylinder to get the air out of the line while still priming the pump ,its building back pressure and fuel cant get past the pump,another way would be is to remove the air cleaner and carefully get a spray container of diesel fuel and spray directly into the air intake and see if it will fire,if so it may pull the air lock thru when the engine starts and till it gets fuel from the pump directly and runs on its own
Posted on Mar 07, 2010
Why doesn't tractor start after injector pump rebuild?
I'd be suspicious that the injector timing is not correct.
When the injector pump was rebuilt, it had to have been removed from the engine.
There will be timing marks on the gears and they have to be lined up for the fuel to be injected at the correct time.
Oct 27, 2015 | Garden
How to change injector pump on a ford tractor 4600.
You will have to get a work shop manual to set the timing marks correctly.
Aug 23, 2014 | Cars & Trucks
Belarus 250as manuals
3 point hitch wont come up. ran out of oil, added more still wont come up. why?
Jan 02, 2012 | GPS
Replaced crank shaft sensor, both timing belts, made sure the timing marks were alined proply, tryed to crank car got fire but car will not crank, may not be getting fuel, is the a fuel shut off, if so...
No fuel shut off, but you can jump the relays,You did the timing belts, how about the cam sensor are they hook up? cycle the key do you hear the fuel pump go active? you should, you need to check injector for pulse , there should be a shrade for fuel pressure check ,push the shrader down does fuel come out,
May 06, 2011 | 2001 Dodge Stratus
I need a diagram schematic for a Belarus 250AS traactor.
hello wath you want to know about that Belarus? wath year is this?
Mar 12, 2011 | Garden
Ran tractor out of fuel try prime got fuel to pump but noting coming out 3cyclinder 250as belarus tractor
Mar 07, 2010 | Garden
Tractor will not start ,checked timing of
Most of your problem is your not getting fuel to the pump so either you have a fuel blockage or a filter blockage or pump diaphragm has air getting into it
a pin hole will cause the problem.
Oct 03, 2009 | RTO Allis Chalmers Tractor 8010, 8030,...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
