Question about Garden
Craftmans brushwacker 32cc, won't start - Garden
  • Garden Master
  • 14,405 Answers
First remove plug,if bad replace,Check air filter,if dirty,replace,dump gas-oil mixture and replace with fresh batch.
Posted on Apr 25, 2017
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
I have a 32cc model p3314 it starts but the chain won't move
If you are talking chain saw there is a safety clutch lever immediately in front of the top handle. this has to be back against the handle and when the chain jams you simply push it forward with your fingers and the chain stops
May 29, 2013 | Tools & Hardware - Others
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Aug 26, 2012 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
My 32cc 4 cycle craftsman weedwacker won't run off choke
Nov 15, 2011 | Garden
When replacing purge bulb on my 32cc craftsman brushwacker I found 3 fuel lines off carb, two were connected to bulb, what's the third? I assume it goes to the other hole on the bottom of my fuel tank but...
the inlet line has the filter on the end in the tank
that goes to the bottom nlet of the carby
the return line goes from under the primer bulb back to the tank
some units run a 3rd line with a filter on the end ( outside of the tank0as that is used to vent the fuel tank as the cap is sealed
the fuel flow is this
through the carby through the pump back to the tank and is only used to prime the float bowl ( needle and seat and diaphragm with fresh fuel and to remove any air in that chamber
Aug 08, 2017 | Craftsman Garden
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
32cc Craftsman Brushwacker
You have to take the machine apart. The first thing is to separate the shaft from the engine. Then take off the shaft driver. There is a screw in the end. It takes a #15 TORX screwdriver. Once that is off, you have to spin off the clutch. To do that, hold the engine somehow and remove the clutch counter-clockwise. With that off, you can then remove the engine from the molding at the other end. The spool will be sitting on the rewind spring so BE CAREFUL. If the spring comes out it will be a big pain! Just lift the spool off, replace the rope and attach as the old one was. Now, you have the rope connected. Place the spool on the spring. Place the rope in the notch at the edge of the spool and slowly wind the spool on the spring. When you have it wound as far as you want, take the rope from the notch and into the spool. Allow the rope to rewind onto the spool. Put everything back as it was before you started and you have finished...Good luck...Lee
Sep 08, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
