What is hydrochlorothiazides used for - Computers & Internet
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
What kin d of a pill is this? large oval white pill "1117"
1117 (Hydrochlorothiazide and Losartan 12.5 mg / 100 mg) This is a blood pressure medication that is used to remove water from the body.
Mar 16, 2017 | Health & Beauty
hydrochlorothiazide is a "water pill that causes you to make more water ( go to the toilet a lot more often with out drinking water)
This helps your body to get rid of excess salt and water
this medication also reduces extra fluid in the body (edema) caused by conditions such as heart failure, liver disease, or kidney disease
google . webmd.com/drugs/2/drug-5310/hydrochlorothiazide-oral/details for uses , side effects, interactions, and photos
I suggest that you seriously consider a conversation with a doctor before using it because kidneys, liver and heart are vital organs
May 28, 2015 | Health & Beauty
What is a round blue pill with watson and 861
Pill imprint WATSON 861 has been identified as Hydrochlorothiazide and lisinopril 12.5 mg / 20 mg.
Hydrochlorothiazide/lisinopril is used in the treatment of high blood pressure; heart failure and belongs to the drug class ACE inhibitors with thiazides. There is positive evidence of human fetal risk during pregnancy. Hydrochlorothiazide/lisinopril 12.5 mg / 20 mg is not subject to the Controlled Substances Act.
Apr 11, 2015 | Health & Beauty
Master reset code for nokia 1202-2 IMEI # 358016/03/449348/0 CODE:0562271
Nokia Mobile Sets Secret Codes
Mobile Set: All Nokia Mobile Sets
Use For: Default Security Code.
Code: 12345
Mobile Set: Nokia Mobiles
Use For: Turn On Enhanced Full Rate Codec.
Code: *3370#
Use For: Turn Off Enhanced Full Rate Codec.
Code: *#3370#
Use For: Turn On Half Rate Codec.
Code: *4720#
Use For: Turn Off Half Rate Codec.
Code: *#4720#
Use For: Show Software Version.
Code: *#0000#
Use For: Also For Show Software Version.
Code: *#9999#
Use For: Show IMEI (International Mobile Equipment Identity).
Code: *#06#
Use For: Show Lock Status of Your Nokia Mobile Set.
Code: #pw+1234567890+1#
Use For: Show Lock Status of Your SIM.
Code: #pw+1234567890+4#
Use For: Show Security Code of Your Mobile Phone.
Code: *#2640#
Use For: Reset Game Score And Timer.
Code: *#73#
Samsung Mobile Sets Secret Codes
Mobile Set: All Samsung Mobile Sets
Code: *#06*
Mobile Set: Samsung 811
Use For: Unlock code / Change roaming code / ID.
Code: 47*869#08#9
Mobile Set: SGH-600 , SGH-2100
Code: *#9999#
Use For: Show Software Version (instructions).
Code: *#0837#
Use For: Show Serial Parameters.
Code: *#0001#
Use For: Activates the smiley when charging.
Code: *#9125#
Use For: Battery status (capacity, voltage, temperature).
Code: *#9998*228#
Use For: Program status.
Code: *#9998*246#
Use For: Change Alarm Buzzer Frequency.
Code: *#9998*289#
Use For: Debug screens.
Code: *#9998*324#
Use For: Watchdog.
Code: *#9998*364#
Use For: EEPROM Error Stack - Use side keys.
Code: *#9998*377#
Use For: Trace Watchdog.
Code: *#9998*427#
Use For: Change LCD contrast - Only with version G60RL01W.
Code: *#9998*523#
Use For: Memory status.
Code: *#9998*636#
Use For: Jig detect.
Code: *#9998*544#
Use For: SIM File Size.
Code: *#9998*746#
Use For: SIM Service Table.
Code: *#9998*77
Jun 03, 2012 | Nokia Cell Phones
I need a fuse diagram for my 2003 ford ranger 2.3L engine
I don't know if this will help you but here are the location numbers. Can't figure out how to copy a picture of the box itself. I do have an entire owners manual I could send you as a PDF if you need it. Hope this helps. Good luck.
Description
1 50A** I/P fuse panel 2 - Not used
3 - Not used 4 - Not used
5 - Not used 6 50A** Anti-lock Brake System (ABS)
pump motor
7 30A* Powertrain Control Module (PCM)
8 20A* Power door locks, Remote entry
9 - Not used 10 - Not used
11 50A** Starter relay, Ignition switch
13 20A* 4x4 Motor 14 - Not used
15 - Not used 16 40A** Blower motor
17 20A** Auxiliary cooling fan 18 - Not used
19 - Not used 20 - Not used
21 10A* PCM memory 22 - Not used
23 20A* Fuel pump motor 24 30A* Headlamps
25 10A* A/C clutch solenoid 26 - Not used
27 - Not used 28 30A* ABS module
29 - Not used 30 15A* Trailer tow
31 20A* Foglamps, Daytime Running Lamps (DRL)
32 - Not used 33 15A* Park Lamp
34, 35, 35, 35 & 37 Not used 38 10A* Left headlamp low beam
39 & 40 Not used 41 20A* Heated oxygen sensors
Jan 28, 2011 | 2003 Ford Ranger Regular Cab
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
