Question about The Office Equipment & Supplies
Is the Unimax a Androud
What is the length and width of the ASW Unimax U673C
Is there an inside adjustment to make the VOLUME LOUDER on my new ANDROID Unimax U673c?
There may be volume increasing apps or patches that you could try(Modding)
But I strongly suggest you not to try those. Because that will surely destroy the output sound quality.
Jun 10, 2017 | Android Cell Phones
The length, l, of a rectangle is 5/2 its width, w. The length, l, of the rectangle is 10 inches. What is the perimeter of the rectangle? What Iis the area of the rectangle, in sauare inches?
We are given the following data:
length = 5/2 * width
length = 10 inWe know through the transitive
property of equality that the following must be true:
5/2 * width = 10 in
We then solve this equation algebraically for width:
width = (10 in) * 2/5
width = 4 in
The perimeter of the rectangle is given by substituting our known values of length and width into the following general equation:
Perimeter = 2 * length + 2 * width
Perimeter = 2(10 in) + 2(4 in) = 28 in
In a similar fashion, we substitute these known values into the general equation for the area of the rectangle to solve for the same:
Area = length * width
Area = (10 in)(4 in)=40 in^2
Nov 29, 2016 | The Computers & Internet
IF LENGTH and WIDTH are given How to find Hight
Never. Even if it a regular shape.
Oct 18, 2016 | Miscellaneous
1904 sq feet how do I convert this to linear feet for roofing
I have done tons of roofing and we always use square feet .length X width= sq ft .like 50 ft long by16 =800 then double to get both sides of roof is 1600 sq ft
Feb 12, 2015 | Cars & Trucks
The perimeter of a rectangle is 600 yards. what are the dimensions of the rectangle if the length is 20 yards more then the width
160 by 140
The perimeter is 600, so 2w+2l=600 where w is the width and l is the length.
Divide both sides by 2: w+l=300
The length is 20 more than the width: l=w+20
Substituting in the previous equation: w+(w+20)=300
Collecting terms: 2w+20=300
Subtract 20 from both sides: 2w=280
Divide by 2: w=140
Thus the width is 140. Substituting into the equation for length: l=140+20
Simplifying: l=160
The width is 140 and the length is 160
Sep 15, 2014 | MathAid Algebra II
X(2x+3)=90
Solve the resulting quadratic equation
2X^2+3X-90=0
Discriminant: (3)^2-4(2)(-90)=729=(27)^2
Two roots
X_1=(1/4)*(-3+27)=6
X-2=(1/4)*(-3-27) =-(15/2), negative
Since the width must be positive, reject the negative root and keep X_1=6
Width =6
Length=2(6)+3=15
Check 6*(15)=90. Checks OK
Apr 23, 2014 | Office Equipment & Supplies
P=228 width is 24 ft less than the length
Say length is x.
Width is x-24.
Perimeter is length plus width plus length plus width = 228.
x + (x-24) + x + (x-24) = 228
4x-48 = 228
4x=276
x=69
length = 69
width = 69-24= 45
check: 45 + 69 + 45 + 69 = 228
Dec 18, 2013 | Computers & Internet
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
Area of rectangle is 4122cm2 .width of rectangle is 3cm.how do i find the length of it
Area = length X width, and you know the area and the width. So,
4122 sq cm = length X 3 cm
length = 4122 sq cm / 3 cm
length = 1374 cm
(That is one long, skinny rectangle, isn't it?)
Mar 02, 2011 | Office Equipment & Supplies
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
27 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
