Question about Dewalt Tools & Hardware - Others
Dewalt dc618. the motor wont shut off - Dewalt Tools & Hardware - Others
    Sergeant:
  • 197 Answers
Trigger may be stuck try a little singer oil or sewing machine oil only a few drops should do it... trigger switch may not be working properly either
Posted on May 04, 2017
SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
  • 583 Answers
SOURCE: dewalt dc608 motor wont run or shoot light stays
seek advice at TOOLKING
Posted on Jul 26, 2009
rcalorisian
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
witserv
  • 144 Answers
SOURCE: DEWALT CORDLESS DC618
You have to take the front part of the case off, and you will see the problem. Either the drive belt is broken or the rubber band like springs have broken. Happened to both of mine after about 2 years of use. I ordered the parts through Dewalt and they have some nice diagrams showing the locations and how things go together. Not too hard to do
Posted on May 26, 2010
  • 1388 Answers
SOURCE: I have dewalt dc618, nail doesn't goes all the
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Posted on Sep 08, 2010
Hello my dewalt dc618 wont fire its bands and belts are all good.it tries to fire but only when no nails a in it.i think the driver is worn can you help thanks.
I've been using dewalt tools exclusively for 15 years. I've fixed numerous drivers, sawzals, etc. I've learn 3 things over and over again. 1 cleaning & lubing are grossly under rated, 2 if one part goes the rest are not far behind & 3 it has never cost me more than $20 to $30 bucks more to have the repair place rebuild it than to fix it myself. And most times they give you a new bulk packaged tool as a rebuilt. My recommendation: have it rebuilt...enjoy the new tool.
Jun 27, 2015 | Dewalt Tools & Hardware - Others
How do I replace the belt on Dewalt cordless dc618?
Remove 2 screws on metal front cover.
Remove screws holding handle halves together and carefully separate (Be careful because trigger spring can fly out on you).
This will expose the belt and allow replacement. There is a spring loaded idler pulley so removal & replacing is easy.
Aug 16, 2014 | Dewalt DC618KA Angled Nailer Kit
Dewalt dc618
If the motor runs and stays running when you depress the nose then the problem is in either the trigger switch or the solenoid.
If the motor runs for a moment and shuts off with the light blinking I would check your battery. These are very temper mental with voltage, and even if your battery just came off the charger & might work in a drill, it may not have 18v to supply the electronics.
Please note - these are not easy tools to work on, I would recommend bringing it to a qualified repair shop near you.
Feb 09, 2014 | Tools & Hardware - Others
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Nov 11, 2012 | Dewalt DC616kn 18 - volt 16 - gauge...
Dc618 brad gun wont fire on bump
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Jul 07, 2012 | Dewalt DC618KA Angled Nailer Kit
May 26, 2010 | Dewalt DC618KA Angled Nailer Kit
My DC618 nailer won't fire .
Check the battey then take it out and check the driving rod. On the front of the gun, flip the latch and make sure it is pushed all the way back.
make sure you have nail, of course. put the battery back in. If al that does not work, have it services at a dewalt service center.
Aug 18, 2009 | Dewalt Tools & Hardware - Others
Dewalt dc618 wont drive a nail
Dec 04, 2008 | Dewalt DC618KA Angled Nailer Kit
Tools & Hardware - Others Logo
342 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
