Question about Car Audio & Video
Front speakers not working
Rear speakers work fine after installing new unit
    Top Expert:
  • Car Audio & ... Master
  • 79,865 Answers
Then you have it connected wrong.
Posted on Apr 25, 2017
Testimonial: "All wires are connected right. The blue power antenna wire is not connected. Does it serve as a cutoff switch, and does it need to be connected to 12 v positive?"
  • yadayada
    yadayada Apr 26, 2017
    Blue is a 12 volt trigger
Rear speakers don't work after new head unit
There could be several reasons why the head unit for your car does not work. The most likely issue is that the head unit is not compatible with your stereo system. You can consult your vehicle owner's manual for speaker issues.---------------------------------------------------------------------------------------
Diagnostic VAG
Dec 17, 2012 | 2004 Toyota Sequoia
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
No sound from cenre and rear speakers
Is there an output section for the speakers on the back of the receiver? if so, make sure to properly install the speaker wires into the correct connectors. It should be the same as for the front speakers. If not, then you will not be able to install center and rear speakers.
Make sure there is nothing wrong with the speakers, or the wires them selves. If you are positive that everything is installed correctly, try using a new batch of speaker wire. If the speaker wire is pre-installed or already attached to the speaker from the factory, you might have to call and report a faulty product or try to find the break in the wire yourself. To make sure the speakers are working properly, be sure to plug them into the same connector as the front speakers to see if they receive the signal. if noise comes out of them when plugged into the front slots, then the speakers themselves are fine, and it is an issue with the wires or the unit itself.
Last, if it is not the speaker, or the wires, then you will have to remove the cover from the receiver or remove the wire inputs from the back of the receiver and make sure there is no connectivity problems with them. There might be a frayed wire, or a wire that has come loose, or a soldering issue. If so, you can try to tackle it yourself, or you might have to bring it into a repair shop, or call Sony.
Hope this helps at all. :D
Last, if you have tried new wires,
Aug 09, 2009 | Sony Audio Players & Recorders
Rear speakers do not work
Either the balance is off on the head unit, or the the out puts (in the head unit) for the rear speakers are blown.
May 15, 2009 | 2002 Mazda 626
Rear Speaker Wont Play
This is most likely a driver issue. I would goto the creative site and use their automated updating tools.
Mar 26, 2009 | Microsoft Computers & Internet
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
