Question about Dryers
My samsung dryer door will not shut - the latch is stuck in the lock position
polarcycle
  • 1392 Answers
SOURCE: how to unlock a broken ford windstar rear door
You will need to remove the hatch panel, and release it manually. It is a pain in the **** with the hatch closed, but it can be done.
Posted on Jun 05, 2009
wracefans24
  • 1985 Answers
SOURCE: I can't shut my chevy Blazer door the latch is in
Put a screw driver or your finger on the closed latch and sort of put a pulling motion on it,Then pull the door handle with your other hand,it will open right up for you
Posted on Dec 25, 2009
  • 1810 Answers
SOURCE: 1995 Chev Suburban rear door latch stuck in locked position
sounds like you lached the door
use a screw driver or some such tool
lift the outer handle and slip your tool in the middle of the lock hole in the door flip the lach open wile holding handle up
Posted on Dec 31, 2009
  • 457 Answers
SOURCE: our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Posted on Feb 26, 2010
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
Rear latch lock stuck in the open position
use a round bar ( a screw driver ) and place it under the latch and pull the latch out as you press the button to unlock as if you were opening the door.
Jan 06, 2014 | 2008 Chevrolet Uplander
2000 hyundai sonata passenger door lock stuck in locked position
If your talking about the teeth/latch that actually engage around the pin to hold the door closed and not the lock you puhs down to lock it. all you have to do is get a screwdriver or anything small and strong you can stick in it and pull the tooth back into the "open" position. You might have to pull the handle out like your opening the door normally while you do this.
Mar 04, 2013 | 2000 Hyundai Sonata
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Rear door lock on 2000 saturn broken. Stuck in
your gonna have to remove the inner dor panel and replace the latch lock assembly
Oct 12, 2009 | 2000 Saturn SC
Two things. 1. the dryer does not shut off when the door is opened. 2. I changed the light bulb, still does not work, and now the door will not fullly close and latch.
your door switch is stuck in the closed position
replace that and you should be ok
as far as closing it may be the switch stopping the door too
Oct 05, 2009 | Kenmore 74872 Gas Dryer
Driver side door will not closed. latch will not open in the door
Take seat belt out of door jamb...
j/k
open the handle like you are trying to open the door, then get a screwdriver, and flip the latch back to open. It is stuck in the shut position. Hurry before it rains.
May 27, 2009 | 1999 Chevrolet Blazer
Dryers Logo
Top Dryers Experts
