Question about Kenwood Audio Players & Recorders
My kenwood ka-550 amp. has low and distorted sound on left channel! What could be the fault?
    Top Expert:
  • Kenwood Master
  • 77,169 Answers
Defective speaker?
Posted on Apr 25, 2017
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Vision 708 mixer amp
Jimbo
I am not sure about the LED fault lights....but I have a few troubleshooting angles to provide a start:
Try checking the power supply at the output devices and compare with the good (Left) channel.
The distortion you are hearing may be due to
low voltage.
This is a stereo amp, so you have a good (Left) channel to compare with. Use a multimeter to compare resistances (no power applied) or voltages (power on) at the components working back from the outputs of each channel. When you find a difference you have located the faulty area.
If you can get an oscilloscope it can also be used to trace the path back from the output of each amp. Good Luck Be careful!
Jan 08, 2008 | Food Mixers
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
May 10, 2015 | Kenwood Audio Players & Recorders
Kenwood ka 7x
salut a tous quelq'un a un amplificateur kenwood ka x7 je veut connaite les tronsistors qui porte cette amplificateur le mien etait enlevr je connais pas les refferonces je demonde de l'aide et mercie beaucoup a +
Oct 05, 2013 | Televison & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
How to hook up 4 speakers up to kenwood k a c 7204
There are 2 ways. The first is in series. Connect in this order (amp)+ to (speaker1)+, (speaker1)- to (speaker2)+, (speaker2)- to (amp)-. Repeat for second channel. The amp will run smoother but you cut your power in half. The second way is parallel. (amp)+ to (speaker1)+ to (speaker2)+, (amp)- to (speaker1)- to (speaker2)-. Repeat for second channel. This will double the power but will cause more heat and distortion. Too much heat and distortion make it no worky.
Apr 16, 2011 | Kenwood Car Audio & Video
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
