Question about Hotpoint Dishwashers
Hotpoint dish washer model number FDEL 31010P stuck on drying cycle
    Top Expert:
  • Hotpoint Master
  • 79,865 Answers
Most likely the control panel is defective.
Posted on Apr 25, 2017
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Cycle isn't using Jet Dry
    Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
    Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
    Model # dwu7702aae has heat delay light coming on during cycle. Why?
    Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
    You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
    Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
    Feb 22, 2009 | Maytag Dishwashers
    The dish washer won't start
    press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
    Jun 09, 2008 | Kenmore Dishwashers
    Dishwasher stopped drying dishes at end of cycle
    check the heating elemt circut and make sure that heated dry has been selected it the machine allows to need the model of the machine for more help
    May 05, 2008 | Dishwashers
    I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
    Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
    Apr 03, 2008 | Washing Machines
    Dishwasher dose not drane
    YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
    May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
    Dishwashers Logo
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
