Question about Hotpoint Dishwashers
Hotpoint dishwasher model number FDEL 31010Pstuck on drying cycle
    Top Expert:
  • Hotpoint Master
  • 79,847 Answers
Please post the question once and wait.
Posted on Apr 25, 2017
My dishwasher does not complete a cycle. It continually washes and just keeps washing without going on to rinse and dry.
Thier are 2 possible things causing the timer not to advance(without knowing the model# i am assuming it does have a timer as oppesed to a touchpad/electronic control)
1) the timer motor is defective and it isn't advancing to the next cycle..to repair that the timer needs to be replaced
2) IF EQUIPPED on your model..the part called the energy option switch is bad and it needs to be replaced...GE/Hotpoint dishwashers used this energy option switch on several models and when it was bad it would not send power to the timer.
If your model has a energy option switch i would highly suspect that as being the problem
GENE
Sep 07, 2011 | Hotpoint Dishwashers
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Cycle isn't using Jet Dry
    Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
    Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
    Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
    This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
    Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    Suds in dishwasher after rinse cycle
    sprinkle some cooking oil in tub this will desolve the suds apperantly u used reg. dish deg.
    Oct 27, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    Dishwasher running on a short cycle, not cleaning
    It is hard to be specific without knowing the model number of your Hotpoint dishwasher and approximately how many years old it is...
    If your dishwasher has a mechanical timer knob that you turn to get the dishwasher started, I would suspect that it is failing (not advancing after a certain point.)
    Please report back with what you find, OK?
    Apr 20, 2009 | Hotpoint Dishwashers
    Hotpoint DF23: Wont go through full cycle
    Sounds like you may have to replace the cycle timer.
    Oct 28, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
    Two Green Lights Flash Mid Cycle.
    It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
    Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
    Cycle doesn't finish
    Its the timer you need a new one they arent hard to get just ring up your local apliance man and tell him (or her) you model number and brand and he will order it and fit it for you
    May 30, 2006 | Hotpoint 24 in. HDA1000Z Built-in...
    Dishwashers Logo
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
