Question about Poulan Garden
Poulan pro 42" riding tractor, engine runs but tracotr won't go in forward or reverse
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Poulan Master
  • 969 Answers
Check to be sure the drive belt is still on the pulleys and not broken
Posted on Apr 27, 2017
Ride lawnmower
bad check valve can do this also bad pump but i would say check valve is bad and chang hydrstatic oil and filter probably really dirty oil
Sep 01, 2014 | Poulan Garden
My poulan pro 500ex runs until I try to go forward or backward then it shuts off
did you check the seat switch ???... unhook the kill wire at the engine ( for testing purposes ONLY ) and then try to move... if it works check you safety system... if not, check your safety system
Aug 30, 2014 | Garden
Tractor seems locked in gear wont go forward or reverse and wont start
push dowm on clutch/brake and let it up releases the brake . has to be pushed down to start though
Jul 13, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Is there any adjustment on the transaxle. It will not pull forward or reverse.
the clutch plate are either worn or the sprag spring pressure plate has no pressure against the clutch facing no longer
Jul 03, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan PRO Model PB20H42YT. It was working great when slowly I lost forwar/reverse motion; freewheel control is engaged properly.
sounds like the drive belt is off or broken, on the lawn tractors if you remove the plate, where you shift gears, you will see the belt.
Oct 29, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
May 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
