Question about Chime Home
I have a linden quartz clock w/Westminster chime. It's quartz runs on 1 D battery. IT keeps time but chime on the 7th on the the hour. IT HAS BUTTONS FOR HOUR AND MIN. But the dial is analog.
SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
Posted on Nov 20, 2008
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
mcdevito75
  • 1970 Answers
SOURCE: I have a Sunbeam Westminster Quartz mantle clock I
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Posted on Jun 23, 2010
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
How to set a classic manor quartz west minister wall clock to chime at the correct time.
Hello Fern Hicks,
Short of ORDERING IN A NEW movement I
would rather try removing the hands... and placing them where they are chime appropriate...
I'm sure there are more convoluted ways of accomplishing the same thing... but I so old & clock oriented... I only turn clocks & timers in the FORWARD direction (very OLD school).
Remove the minutes hand (from where-ever it strikes)...
Move the hour hand (only if necessary & replace the minute hand as appropriate to the movement strike.
Classic Manor Quartz Westminster Chime Pendulum Clock0 results You may...
Carnac the Magnificent
Mar 26, 2017 | Chime Home
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Clock chimes
What is the problem? Linden is a German manufacturer... I work on German timepieces daily.
Jan 11, 2014 | Seiko Mantel Clock
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Fred
Apr 05, 2010 | Seiko Mantel Clock
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
Timex westminster anniversary chime clock doesn't chime correct number
Oct 04, 2008 | Watches
Home Logo
42 people viewed this question
Top Chime Home Experts
spencer hughey
Level 1 Expert
deton8 von Splosion
Are you a Chime Home Expert? Answer questions, earn points and help others
