Question about Husqvarna Garden
Husqvarna zero turn mower dies when u disengage parking brake..
  • Clyde Ottaway Aug 26, 2017
    yes faulty brake switch
    Visited the website for 20 consecutive days.
  • Husqvarna Expert
  • 136 Answers
Faulty seat switch
Posted on Aug 25, 2017
SOURCE: parking brake will not disengage on 2005 jaguar s type
hi mike i had the very same problem with my 55 plate s type this morning 4 feb 2009 had driven a journey of 20+ miles at 9am with 4" of snow on the ground and at this point no problems and i would assume the discs and pads would have been toastie hot and the assoc parts ,
but after a quick stop for ten minutes i restarted the car and drove away up a slight incline in snow /slush the rear wheels lost traction and the dsc sybol illuminated on the dash after getting no traction in this mode switched dsc off and managed to get some traction by hook or crook on reaching the major grit treated road and gaining full trction the dsc was re selected
as per normal start up but then i noticed that i had the amber oval warning light on the dash and park brake fault promt on the info lcd .
On stopping the car i tried to switch off the engine and re start to see if this would reset or clear the display
resulting in the car still showing same fault msg and this time unable to select a gear and the gear selector stuck in park
on calling jaguar assist an engineer arrived within a reasonable time with laptop and conections to do a diognostic scan
finding that his pc would not cummnicate with my car following several attemps the engineer went on to get the park brake disengaged by these next two steps and i can only say that this worked sufficently to get the vehicle off the road to a more suitable investigating area
in my case my drive way less than 1/4 mile away
step 1. inside the boot lift the floor to expose spare wheel and battery compartment
then on drivers side, the interior that covers the rear light cluster should be teesed back there are two black fixings that secure this in place one being 1/4 turn the other a full thread plastic nut
once this liner is pulled back (easier with two people )there is a white (PARK BRAKE ) module sat there with a multi plug going in .
this multiplug contains severa wires going into it.
from what the engineer said the two your intrested are clearly fatter than the rest and control the motors that engage parking brake force to the calipers .
now heres the clever bit take 2 peices of wire at least 2 feet long making sure the ignition is off and key out
(this is also where a friend comes in handy )
where the battery is, remove the cover from atop of the live + terminal and place place /hold /secure one wire to each batery terminal this done then carefully touch the exposed other ends of each wire into the little gaps where the individual fat wires go into the multiplug trial and error will do one of two things
1/ nothing and the brake motors will just remain powered to keep brake force applied so by swapping them round should give the desired result in powering the motors to RELEASE breaking force and thus disengage
so stage one complete but error msg and drive selector still not moving
step 2.
go to
center console where ashtray is ,lift cover to expose cigar lighter
the trim panel that is sheild shaped and surrounds the gear selector should be grasped firmly by placing your four fingertips along the flat top area where it meets the ashtray and prise upwards toward the roof this removes the trim plate without any damage and exposes the Jgate selector linkage and the plastic dust shroud that rotates when various positions are selected .
now on the pasenger side look into the gap that has become visable and a small aprox 1/2" to 3/4 " protrusion with a flat straight lump similar to a slotted screw but in reverse if you get my drift sits on the side of the selector by rotating this button/protrusion with your finger tip or screw driver tip and trying to move the gear selector from its park position this should allow the selector to move down the gate,while the engineer did this in my case i was sat in the drivers seat and had the car held on the foot brake so that the normal protocols of selecting were observed also the engine was running on moving the selector neutral was selected and at no time was park re selected til the vehicle was recovered to my drive way
however whilst driving the car the parkbrake fault warnings were still present and the asssoc beeps were audible .
strangly once we were on my drive the car was re plugged in to diagnostic laptop after the engineer had tried it on the land rover disco he had attended in and this done just to elliminate that his laptop and cables were funcioning correctly which they were ,
my car began to communicate with his machine and a reset was done
the get you out the S**T CHEATS were put back to normal
the PARK BRAKE FAULT warning was cleared and so far so good
its been very intresting to note that all the posts i have read on the web seem to refer to 2005 models and that adverse wheather conditions seem to play there part i was relieved to have this fixed and very grateful to the engineer who was so very helpful and happy to share his wealth of knowledge without which i could not have passed this on
Posted on Feb 05, 2009
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Posted on May 03, 2009
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Posted on Jun 01, 2009
  • 95 Answers
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Posted on Jul 31, 2009
My zero turn Husqvarna mower Starts good, but kills it when parking brake is taken off! Everything is in place otherwise.
You have a safety switch not working. First check your seat switch. Try to engage the PTO with the parking brake on. Blades should start but die when brake is released. My guess, seat switch. Check it is completely connected, these can be hard to connect. Make sure you hear a "click" when the connector is pressed into the switch.
Apr 07, 2017 | Husqvarna Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
When parking brake is moved off position, the engine shuts off on my rz5426 zero turn mower.
One of the safety switches is bad or not making contact. Check the switches on the levers and the seat switch.
Jul 19, 2014 | Husqvarna Rz5426 54" Zero Turn Lawn Mower...
Engine shuts off when you release the parking brake
More than likely you have the blade engaged, disengage the mowing blade and try the parking brake again
Apr 07, 2014 | Husqvarna Zero Turn Mower Z5426
I just purchased the new Husqvarna MZ6128 Zero Turn. Was dropped at home on Sunday.. with the parking brake on and deck in the traveling mode and handle bars in neutral it will start..when returning the...
Read the manual. These so called "problems" are standard safety features that someone should have gone over with you. Sounds like poor salesmanship. When starting the mower the bars should be out and the park brake pulled. Then disengage the parkbrake and pull the arms in to drive the mower. Do exactly the opposite to get off the mower. I just bought one today every model I looked at was like this.
May 24, 2011 | Husqvarna Zero Turn Mower Z5426
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Jun 06, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Garden Logo
158 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
