Question about Kitchen Appliances - Others
Need a manual and replacement element cover plate for a TVS347 steamer
Rational Oven CM201 Shows Fault code E16 then E6 Then Thermal overload trips. Please help
Phone the dealer/ manufacturer to explain what are those codes for, and ask him how can they be corrected. electronic components need technician to fix those problems. if not so, buy another brand. and before you connect read the instruction manual and comprehend every step you take.
Feb 22, 2015 | Ovens
The plastic plate that came with my rice cooker, what is it, I lost my manual
What is the actual model number? HB makes several and none of the current or listed ones are 37531.
37541 is a current model, also none are "10 Cup" and the "plate" or tray, is for steaming vegetables.
http://www.hamiltonbeach.com/products/rice-cookers-amp-food-steamers-digital-simplicity-rice-cooker-and-steamer-37541.html
Sep 28, 2012 | Hamilton Beach 37531 10-Cup Rice Cooker
How do i install new heating element
Unplug the machine, remove the back cover and locate the terminals attached to the element, Disconnect them and unscrew the plates that hold the element in place. Remove the element from the holding lugs and take it out. Fitting the new element is the reverse order of the above. Make sure that the socket remains unplugged until you have replaced the rear cover plate. Run the machine and check for leaks
Feb 18, 2011 | Whirlpool Dishwashers
How to use steamer
Do you mean how to use the steamer plate in a rice cooker?
If so put it in bottom of pan so the holes are uppermost and add water to barely cover the plate and then place whatever you want to steam on the plate. Turn rice cooker on.
Dec 15, 2010 | Kitchen Appliances - Others
In regards to the Home Touch Steamer: I turned it on and then noticed a burnt plastic smell about 30 seconds later. I looked down and the base of the steamer was sparking inside the plastic covering and...
Sorry to hear that! The burnt plastic smell indicates that the element over heated to a point that the heat radiation melted the substance. The internal heating element has shorted out and took with it vital accessories necessary for normal function of the steamer. Too many parts have become inoperative and the cost of repair is excessive. The only solution is to replace the streamer. Do not plug the defective unit into a live power outlet for safety reasons.
Feb 03, 2018 | Irons
How do I remove a Samsung Dryer DV4006 heating element
You will NOT have to remove the drum, as the previous poster said. Unplug the dryer (VERY IMPORTANT). Undo the screws for the cover at the top right at the back of the dryer. Your element is here. Detach it from the cover plate. The undo the bottom cover plate so you can access the plug where the element attaches. You will need to reach in and manipulate the wire out of the clips (easy).
To put it back, just reverse what I've said.
Mar 10, 2010 | Dryers
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
3 CUP AROMA RICE COOKER WILL NOT HEAT --ONLY 4 MONTHS OLD
1. Is the cooking pot filled with water? If there is no weight, it will not turn on.
2. Is there a pilot light? If no power, you have a unit that was probably returned by someone else.
3. The heating element/plate thermal fuse may be blown. Either replace the fuse or the whole unit.
Mar 06, 2009 | Kitchen Appliances - Others
How to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Oct 25, 2007 | Fisher and Paykel AeroTech - OS302M...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
