Question about Acer Computers & Internet
I just bought an Polaroid optical wireless mouse for my Acer Chromebook. I can't get it to connect. I have tried everything and nothing works. Do I need to install a driver?
egadgetguy
  • 258 Answers
SOURCE: Optical Wireless mouse does not connect
uninstall blue tooth software and start over from scratch.
Posted on Aug 14, 2008
SOURCE: microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Posted on Nov 24, 2008
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Posted on Apr 04, 2009
Techjoel
  • 79 Answers
SOURCE: Sylvania wireless mouse not working
Press the button on the reciever, then press the small recessed button on the bottom of the mouse (may need to use point of a pen).
Good luck,
Techjoel
Posted on May 25, 2009
  • 6 Answers
SOURCE: The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Posted on Sep 04, 2009
How do i use the staples wireless optical mouse with my chromebook?
Wireless mouse and keyboard are supposed to work on chromebook. It is supposed to work just by inserting USB dongel in port. If won't work, test it on a Windows or Mac computer. Wireless mouse and keyboard are supposed to work on chromebook, see customers report at amazon
Amazon com Customer Reviews Logitech Wireless Mouse M560 for Windows 7 8...
But, if works on Windows, it simply won't work for chromebook. No way!
Mar 10, 2015 | Staples Wireless Optical Mouse, Silver
Can you use a mouse with the chrome book?
Which specific Chromebook do you have? The Samsung Chromebook has USB ports on the back of the unit (below the hinge for the screen). The Acer C720 Chromebook has one USB port on each side. Most basic mice should work. (Some gaming mice and mice with unifying adapters might have issues.) Some report needing to disconnect and reconnect the mouse after turning on the Chromebook to get it to work. Other models can connect to a bluetooth mouse, like this: http://www.amazon.com/Logitech-Cordless-Optical-Bluetooth-Charcoal/dp/B000BDH2Y8 . Enable Bluetooth and then synch the mouse using the PIN provided in the documentation.
Please note: adding these external devices may reduce the length of time that you can use the Chromebook before recharging the battery.
I hope this helps.
May 12, 2014 | AOL Computers & Internet
How do I activate the Hp Link 5 wireless mouse in order to use it with my Acer Chromebook
if not coming on the mouse is either not switched on or not compatible with your chromebook
Feb 20, 2013 | HP Hewlett-Packard Link-5 Wireless Optical...
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Help me make this wireless mouse work!
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
Apr 23, 2009 | HP Wireless Optical Mouse
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
Jan 25, 2009 | Logitech Cordless Mouse
Wireless mouse wont work
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Micro Innovations Wireless Optical Travel...
HP Optical Mouse right click button does not work
you just need to replace the optical mouse
Feb 09, 2008 | HP Wireless Optical Mouse
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
