Question about Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WS-55413 - I want to use DVI input for HDMI connection
I have a Blu ray DVD player with HDMI output. I want to use and HDMI-to-DVI adapter to connect to the TV's DVI input. Will this work?
How do I assign the DVI input for selection?
4 Suggested Answers
Drew_1
  • 10 Answers
SOURCE: Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Posted on Feb 10, 2009
  • 57 Answers
SOURCE: Grainy apperance when HDMI components turnd on
HDMI cable change its sub standard.
Posted on Jul 08, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
Posted on May 12, 2010
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
Inputing HDMI signal to a WS-55313 55 via an HDMI-DVI cable
HDMI standard is a bear, especially "Older" versions. It should be possible to input HDMI to a DVI, either DVI-I or DVI-D, input, there are however DVI analogue too, in fact we have, 3 type of them, they are, DVI-I, DVI-A & DVI-D.... Also some HDMI do not send the Audio over it, as it should, so all in all it can be a pickle. So you MUST get a converter that works with your sort of DVI. You would have to select that DVI, input, which may be under Auxillary, or External or the like, try scrolling through your AV inputs, see if you "Find" it. if so, the set will "Read" the signal and display it automatically. The Audio, however will have to be done via the AV sockets, the Red & White stereo IN, from the DVD etc. If you have any other inputs such as Component Video, Green, Red, Blue, then this is the best way... The Audio, again must be routed to the AV, the Red & White Jacks. So ensure you have those outputs on your new DVD.
I have included a couple of links below about DVI & HDMI for your convenience. http://www.datapro.net/techinfo/dvi_info.html http://www.hdmi.org/learningcenter/faq.aspx
Feb 11, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Bought blu ray player but tv doesn't have hdmi input
Try a S-Video cable for the video output.Use a RCA cable for audio output should work simular.
Feb 06, 2010 | Mitsubishi VS-70803 70 in. Rear Projection...
Is there a way to take advantage of Blu-Ray players with this TV? Is there an adapter that takes the HDMI coming out of the player and allows you to connect to the TV (at least I did not see any HDMI...
Yes, you can purchase a cable with the Mitsubishi's DVI terminal on one end an an HDMI terminal on the other, allowing you to connect HDMI Blu-Ray players. I've have the cable for years and it works great.
Jan 23, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Jan 04, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WD-52628 52" Projection HDTV Logo
538 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
