Question about The Optics
HOW DO I GET THE BB TO ENTER THE FIRING CHAMBER WITHOUT A LOT OF TROULE.
I can't seem to be able to load any bb ints the chamber to shoot, what is wrong?
the loading chamber is blocked for some reason. Take it to a gunsmith. You are using the right size? There are three. .22 and .25 are similar.
Nov 03, 2017 | The Optics
I have a password on my blackberry . I changed it now I forgot it .How do I open it without loosing my info on it
I assume that you have Blackberry Protect activated on the Phone...so all you will have to do is enter the Password 10 times and the BB will reset Phone to factory defaults and then you will log into BB Protect with your Phone and restore from backuP normally BB Protect backsuP weekly by default
Oct 23, 2013 | RIM BlackBerry Bold 9000 Smartphone
Loading mechinizm does not pick up a bb and load for fireing. Plenty in there; can hear them rattle.
The bolt should be magnetized to catch a bb. Some rifle have to load a magazine upside down to get the bbs lined up on the top with a small thumb switch. Then when you bring the bolt back the mag pickup on the bolt should take a bb from the top and load into the chamber.
Oct 15, 2013 | Crosman Optics
Pellet will not stay in chamber of pellet gun
The chamber may be worn. The pellet is just big enough to stay in the chamber without falling out. A worn chamber will allow this to happen.
Jun 29, 2013 | Crosman Benjamin Sheridan 392 Air Rifle...
I have a winchester 1000 and when i break the barrel it shoots
sounds like there is an obstruction between the barrel and the firing chamber.try cleaning the barrel and the chamber. If this does not work make sure when you place the barrel in the firing position that everything is lining up correctly allowing for an efficient release of air from the chamber.
Oct 13, 2010 | Daisy Winchester 1000B Synthetic Stock...
Crosman 66c air rifle wont fire
See the service manual here:
http://www.crosman.com/airguns/service/manuals
Whether or not air is coming out of the muzzle when you fire it tells you a lot.
May 24, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
I have a walther bb gun, need to find parts..
HI. YOUR BB GUN HAS NO FIRING PIN,,IT USES A SMALL TYPE OF RELEASE TO LET THE SPRING GO IF THAT IS THE TYPE OF BB GUN YOU HAVE. IF ITS THE (CO2) TYPE IT RUNS A LITTLE DIFFERENT BUT NO FIRING PIN. I HOPE THIS HELPS. JIMBO
Aug 15, 2009 | Sport & Outdoor - Others
How do you get a BB into an AIR 17 chamber to fire.
Hi Dan. Here's a link for the manual for a Crosman AIR-17. It will explain loading and unloading the gun. It's a great air rifle and a lot of fun to shoot. I've got one and it's definitely a keeper.
http://www.crosman.com/pdf/manuals/crosman/AIR17/CAIR17-OM.pdf
Jul 08, 2009 | Sport & Outdoor - Others
Optics Logo
27 people viewed this question
Top The Optics Experts
David Clark
David Clark
Paul Carew
Are you a The Optic Expert? Answer questions, earn points and help others
