Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer won't drain or spin the mod# is LBR5432Lq0
    Sniper:
  • 57 Answers
Hi.
What you describe here is a common problem seen in many washers.
I can tell you the door switch has gone bad, but if you want to check it, use an ohm meter to see if the circuit is closed when the lid is shut. If it reads open, replace the door switch.
Posted on Jul 25, 2009
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Mod#WHRE555ok2ww. Wont spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2011 | GE WHRE5550K Top Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Washer drains but will not spin. Washer is just under 2 years old one person is all that uses this washer. still drain in the spin cycle but won,t spin out clothes. Thanks John Foster
Does it agitate and run through the cycles? What mod.number? It may be the motor drive coupler. If it is a direct drive. The transmissions are usually not the prob. The couplers are. They are fairly easy to change. from undrneath you can remove the water pump by prying off the retaining strapps (2). Pull the pump off. Remove the screws retaining the straps (2) holding the motor and pry them off. Pull the motor off and the cooupler consists of 3 parts. 2 (usually) plastic and one rubber. The plastic may be broken or the rubber may be worn out. You can usually tell. The plastic parts also crack around the shafts and slip. They are avalible online for about $14. Usually changed in less than an hour. Trying to help but I have limited info here.
Aug 05, 2009 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
138 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
