Question about Tools & Hardware - Others
Battery powered recip saw keeps stopping after a few seconds and must be started again over and over, battery is fully charged
  • 67 Answers
Do you have another battery to try - if still persists - you have a problem with the saw - if not take it to a repair shop - they should be able to isolate the problem quickly.
Posted on Apr 25, 2017
My kenmore stick vaccum model. 116.36025510C stops after a few seconds and the light is blinking. This is after it indicates it has been fully charged
It sounds like the battery is no good, even if it shows full charge that doesn't preclude a defective battery.
Dec 01, 2016 | Computers & Internet
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Hey I have an hdmx jam xt extreme wireless Bluetooth speaker & after a few seconds after I have paired with mine or a friends phone the music will stop playing, this sometimes doesn't happen if the volume...
To me it looks as if the battery is not charged ok. I'm not sure if you can monitor the battery voltage, but if you could, and you saw the voltage drop bellow a certain voltage and the speaker stopped there, and you could repeat this that would be the case. But perhaps you just charge the battery and discharge it a few times, before you panic. Some batteries only start working with full power after a few charges.
Jun 23, 2014 | Radio Communications
New SKILSAW 5995 used once to cut 1/4 inch plywood, no problem. Several months pass and I went to cut a pine board, the blade touched the wood and stopped. I recharged the batteries and tried again, two...
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Aug 12, 2011 | Skil Saws
I HAVE A 36 VOLT DEWALT RECIP SAW, THE BATTERIES ARE NEW AND SO IS THE CHARGER. BUT THE CHARGER KEEPS BLINKING AS THOUGH THE BATTERIES ARE RUINED. CAN I RESET THE BATTERIES TO TEST
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
Feb 05, 2010 | Dewalt Drills
Hitachi 18v recip saw just quits.....battery life or saw problem?
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
Dec 31, 2008 | Hitachi 18V Lithium Ion Cordless Hammer...
Battery is always dead
This is a common problem with the Q. It uses a lot of juice to run all of the programs. There are a few things you can do to help with this problem. First, Kill all of your running programs before going to bed. You can do this by selecting Start, then System Tools, then select the Task Manager icon, then choose Menu, then "Kill All". Since you will repeat this a lot it is a good idea to save the Task Manager program as a speed dial. Second, Make sure you are not overcharging you battery. When it is fully charged, stop charging. Charge it again when the battery runs all the way down. Then repeat. This will "reset" your battery. Third, make sure you have a second battery and a battery charger. When you go to bed at night, simply replace the battery with a fully charged one. Finally, try this...keep your phone plugged in at night. Then run it all the way down before you replace the battery. Reset the battery often as you lifetime for the battery will diminish the more you keep it charged all night.
Jun 15, 2008 | Motorola Mobility Moto Q
Tools & Hardware - Others Logo
98 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
