Can i install on win7 - Computers & Internet
I need to boot Win7 by USB flash Drive created by a 2.5"FF SATA drive.
If you can tell your BIOS to use USB as the first boot device and the USB is from an ISO of Win7, it should work but your laptop won't be happy as the drivers may be wrong.
Dec 07, 2014 | Computers & Internet
Windows xp startup problem
You may need to "wipe" or reformat your entire C drive to be able to install Windows program again. I would suggest installing WIN7 program as WIN XP is at its end of life cycle for that operating system and Microsoft may not support it any longer.
If possible try installing WIN7 once again, and if requested to reformat or do an entire install, choose YES.
WIN 7 should then reformat your C drive, erase everything that is on it and then install as WIN7 program.
Be sure you have your program license key to install WIN7.
Mar 31, 2014 | Dell Inspiron 6400 Notebook
I need driver for Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive to complete a win7 install
You're not going to get an install then. If that is NOT an OEM Install disc, you might have to try another drive to do the install with. Most ATAPI/IDE Drives are run by the BIOS.
Feb 01, 2014 | Compaq HITACHI GD2000 2X ATAPI/E IDE...
I have a "i-nix NWC-15-2L
That means the win7 has already some driver installed in it.. Unistall the driver from win7 and reinstall your webcam driver from the CD which you got with your webcam (check whether its compatible with win7).. Hope this wil solve your problem
May 13, 2011 | Computers & Internet
Can you give me a link to download a driver for Protax DC500t camera that works on windows7? The disk I have only works on windows xp Thanks, Peter
If your Windows7 is x32 version, then your driver should work in it. But if you have x64 version, you'll get some trouble to install driver for XP in Win7 PCs. I've stuck the same problem like you, but my case was modem problem. Programs like game or other application that can be installed in XP usually can be installed in Win7 64 bit and extracted in Program Files (x86), but driver case is an exception.
I've search via google but I got nothing. Actually, there is a way to install XP driver in Win7 which is use XP Mode in Win7, but you must upgrade your OS to Win7 Ultimate (I think, see microsoft website to make sure) so you can use this mode.
or
you can install two OS in your PC, Win7 and Win XP maybe. When you want to install driver for XP or if you want to do some work related to this driver, you can start up with XP OS, but if you want to do other work, use Win7.
This is so unconvenient, but better than you can't connect your camera to your PC.
Good luck Peter !
Hope this help and be kind to rate my answer please.
(^_^)
Jan 06, 2011 | Cameras
How to upgrade window vista to window 7
Upgrade is not suggested,
I would prefer you to install a fresh copy of Win7 on another partition on your PC's harddrive using a Win7 install CD or from a medium (Harddisk, USB device etc)
Why, because your Vista is in perfect working conditon I guess so, so why spoil it.
Many of the hardwares you use in your PC currently (like printer, webcam etc) work fine now.
But when you install Win7 they will need new drivers for it to function perfeclty and I am sure you'll have diffculty locating them.
So i suggest you keep your exisiting Vista and keep using it for your day to day work.
Install Win7 on a new partition and try to get used to it while installing all required drivers and softwares for them to function.
Once your Win7 is perfect then you can slowly SUNSET Win Vista.
Nov 18, 2010 | Computers & Internet
Instaling windows 7 in vaio laptop have vista orginal windows how solving the problem in instaling windows 7?
if your system came with vista originally the issue would be is you would need to know what version of vista you have on your system, the version makes the difference if you have vista home premium then your windows 7 should be a win7 Home premium as well, because if you are upgrading vista using your win7 disc and your windows version are different for example you have vista Home premium and your win7 is win7 ultimate and you do an upgrade the problem will be your product key,
but if you have a retail version of win7 and you are installing it on your laptop Vaio insert the disc in the DVD-drive win7 needs a DVD reader to be able to install win7 if you have a cd-rom it wont work, then turn the laptop off power it back up keep on tapping f12 it should bring you a boot menu, select ODD or which ever is your dvd drive then press enter then enter again if it says on the screen press any key to boot to CD, this should begin win7 installation on the screen saying windows is loading files the so on ans so fort ^_^ this will over write everything in vista but in win7 it will still create a windows.old folder from vista only from the my documents folder my picture and my music and my video and desktop Items but remember application icons will not work on win7 you may need to reinstall the program again for it to work on win7 and yeah make sure that you choose custom/advance in the selection screen do no select upgrade unless you vista and win7 are the same version eg. Vista Home premium / Win7 Home premium ^_^
Jun 03, 2010 | Sony VAIO VGN-FW390JFB Notebook
HP TX1110us, custom install to win7, RC inoperable
To get the remote to work on Win7 you need to install the CIR driver. Check the driver download page for your product for the appropriate Win7 driver. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-75405-1&jumpid=reg_R1002_USEN If a Win7 driver is not available then the Vista driver will also work. Please check with this?Plz vote if this resolves issue.. Dreamkam
May 20, 2010 | HP Pavilion tx1000z Notebook
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
