Question about Sceptre Computers & Internet
I have sceptre svc 300 webcam so can i install on win7
I cant fix my webcam logitech v-uam27a p/n:861210 for win7 64bit
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 17, 2013 | Logitech QuickCam Computers & Internet
Tip
Thanks for the guidance. My unique problem with the SVC-300 on a re-install --...
Removing the software and reinstalling it using a "clean boot" may resolve the installation problems you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, you should not have any problem now.
on Dec 04, 2008 | Logitech QuickCam Communicate STX Personal...
Win7 + driver + PD0040
May 12, 2012 | Creative Labs Video Blaster WebCam Plus
I have a "i-nix NWC-15-2L
That means the win7 has already some driver installed in it.. Unistall the driver from win7 and reinstall your webcam driver from the CD which you got with your webcam (check whether its compatible with win7).. Hope this wil solve your problem
May 13, 2011 | Computers & Internet
046D 0928 for win7 no drivers
Mar 15, 2011 | Logitech QuickCam Express Web Camera
Not install to windows7
may your win7 is win7 64bit but your camera driver is for win7 32bit, reinstall driver using driver for win7 64 bit
Jan 23, 2011 | A4tech PK-635 Webcam
Hi, i have a genius nb 300 and cant install it on win7
HI There,
The link below will take you to the latest Driver for your Cam. It is rated to support Vista and as a general rule most Vista Drivers will run a device on Windows 7. The site recommends (and so do I) that you set a System Restore Point before you install the driver so you can turn right around and completely remove the driver from your W7 if it has problems.
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-VideoCAM-NB300-10001.shtml
I hope it works for you. If it deosn't, please don't trash my rating with a thumbs down because Genius is not enough of a Genius to support W7. :-)
Aug 04, 2010 | Computers & Internet
When buying a web cam do you get one compatible with the tower or the screen...for example my friend has a sceptre screen and a dell tower
The screen is not an important consideration
He needs to be looking for a webcam:-
1) With a built in mic
2) Suitable for his OS - especially if he has Windows 7
3) Compatible with the chat programs he wants to use it in . For example Skype, Yahoo Messenger and Windows Live Messenger
Jan 19, 2010 | Sceptre SVC 300 Webcam
Computers & Internet Logo
22 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
