Question about Sewing Machines
Hi My husband took apart my sewing machine because the bobbin cam lift actuator was broken. Now we don't know how to set it again to that I can wind my bobbin. Can you help me?
I forgot to say that my sewing machine is a Singer Futura 900
  • Sewing Machines Master
  • 11,703 Answers
You can try searching for:
Make Model parts diagram
Posted on Apr 25, 2017
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
Feb 25, 2012 | Brother XL-2230 Mechanical Sewing Machine
How to wind the bobin on a singer 7050
To get that same thread onto the bobbin, you'll need to windit. Here are the steps:1. Removethebobbin from the sewing machine. If your machine has a free arm, you'llhave to remove this first. Open the bobbin door to reveal the bobbin case, forvertical loading models. If your machine has a drop-in bobbin (horizontalloading) you may have to simply slide the metal plate open, which sitsunderneath the presser foot.2. Lift the latchand pull the bobbin case out of the machine (for vertical loaders). Butfor drop-in bobbins, simply lift the bobbin out of the housing.3. Tip the bobbincase over and let the bobbin fall into your hand. (Some bobbin caseshave a latch on the side, that when lifted releases the bobbin). If the bobbinhas another color thread on it, use a new bobbin. Or, if it's not too muchthread, roll it all off and reuse the bobbin. Just make sure the bobbin youwind begins empty. (But in a pinch, you can wind a new color thread over theold color. Just know that you may have to rewind the bobbin fairly soon, as thedesired color thread finishes faster.4. Place yourselected thread onto the spindle and insert a holder over it, if there is one(usually on horizontal spindles only). Many machines just use gravity toretain the thread, so if your spindle is vertical and you have no such part,don't worry about it. If thisis a brand new spool of thread, you may need to free the end. Look for a smallnotch on one end of the spool. You may have to peel back the label a bit to getat it. Then yank it free.5. Loop the free endof the thread over the bobbin tensioner and any hooks on it. Thelocation of this part varies, but it generally looks about like this. Thread the end of the thread through the pinhole in the top of the bobbin. 6. Press the bobbinall the way onto the bobbin winding spindle. Make sure any springs orclips engage. Put it on so that the end of the thread that you put through thepin hole sticks out towards you (or sticks up, depending on if your bobbinwinder is at the top of your machine). 7. Disengage theneedle mechanism. Many machines have this control in the handwheel. It may require a push, pull or twist of the middle of the hand wheel.Check your sewing machine manual to be sure. The sewing machine may run fasterwhen winding a bobbin than when sewing and you don't want the needle moving upand down wildly. Engage the bobbinwinding mechanism. On some machines, it's done by pushing the bobbinspindle over to one side. You may also need to move the stitch selector to abobbin winding position.8. Hold the free endof the thread and, keeping fingers clear of all moving parts, press the footpedal or knee lever. The bobbin spindle will turn. If you have thebobbin threaded correctly, the bobbin will wind smoothly, evenly, and snugly,with perhaps a slight bulge in the middle. You should cut off the end of thethread you were holding in your hand (very close to the bobbin) as soon asthere's enough thread on the bobbin to hold itself in place so it won't slipout. This will prevent this thread from tangling onto any moving parts.9. Fill the bobbincompletely. It may seem like a lot of thread, but you don't wantto run out too soon while you're sewing. Many machines have a built-in deviceto stop winding when the bobbin is full, often a small blade that automaticallycuts the thread when the wound bobbin is full. If your machine has such adevice, let it tell you how much to fill the bobbin. If not, fill the bobbin nofurther than its edges. Hold the bobbinand case so that they are oriented as shown. Check that thebobbin will unwind in the correct direction. If not, flip it.10. Insert thebobbin into the bobbin case. Pullthe thread under the bobbin tensioner (a thin metal latch). The threadshould advance with a little resistance when you pull at it. Allow this excessthread to just hang. Lift the latch onthe bobbin case and hold it as shown.11. Insert thebobbin case into its housing. Make sure it is all the way engaged (youshould hear it click into place) and that the direction is correct. The bobbincase shouldn't spin and shouldn't come loose when you release the tab. Itshould be locked in. And the loose end of the thread should hang free. Do notclose the bobbin door.12. Re-engage theneedle at the hand wheel, disengage the bobbin winder, and set the machine backtoa straight, forward stitch. Thread the machine with the top thread as usual. Once the threadis through the needle, you must raise the bobbin thread. Hold the end of thethread with your free hand. Turn thehand wheel towards yourself. The needle should go down and back up to itshighest position. One full rotation should do it. The top thread will passaround the bobbin.13. Watch as the topthread pulls the bobbin thread up through the hole in the plate under thepresser foot. Pull the looseends to extend them, and continue to hold them firmly so they don't get tangledas you begin to sew.Closethe bobbin door before sewing.Hope this will help you. Good Luck.
Oct 08, 2011 | Sewing Machines
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
I just purchased a Tacsew T111-155 sewing machine with a bobbin rewinder. Since the bobbin rewinder runs off the drive belt, how do you rewind the bobbin without the needle moving? Is there a button or a...
Hi Diane...you can wind bobbins while you are sewing your product, or you can wind them seperately. To wind them seperately, pull out the bobbin case, lift the presser feet up and lock them in the up position, undo the threading beyond the tension assembly. The takeup will create a birdsnest if you don;t pull the thread from it. Wind your bobbins, the re-thread your machine, insert your bobbin case, drop the presser feet, pick up the bobbin thread and sew away. If you need any other input, call me at 888-283-9640.
Robert with National Sewing Supply
Jan 01, 2011 | Sewing Machines
Bobbin won't thread
I just bought my White sewing machine used and the model #967.I had problem winding a bobbin so my husband helped me. what I had to do was hold the arm with the bobbin on up agains the wheel. I know it seems to be a pain but this machine has all kind of attachments.
Apr 01, 2009 | White Sewing 979
Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Nov 25, 2008 | Janome Memory Craft 9000 Computerized...
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Nov 04, 2007 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
