Question about Imperial IFS40 Deep Fryer
How to fix a gas fryer trouble to get it on.
We can get the pilot on ok then we turn it to the on posicion same times gets on but then shut off.
  • 54 Answers
It is either the gas valve or the piece that the pilot light heats up. After the pilot light gets so hot it heats the copper tube looking thing up and then that goes to a little box that kicks a little switch and lets the power through to the gas valve which then opens and ignites the burner. You can check for continuity on the 2 poles on the switch when it gets hot.
Posted on Jul 24, 2009
The burners will not light. The pilot does light. I had my staff try to hit anything that looked a reset, but I don't know if the high limit switch has a reset or if the switch itself is bad.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
Jun 11, 2011 | Pitco Frialator 35CS Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
Apr 11, 2010 | Pitco Frialator SG18S Deep Fryer
Fryer heats up to 550 degrees and shuts down pilot and triggers the reset button which thermostat is it the operating on or the high end on i have already replaced the gas valve
Either the thermostat is bad or there is a gas leak between the gas valve and the thermostat. Use a soap solution and apply it to the 1/4" gas lines between the thermostat and gas valve. If bubbles appear then you need to fix the gas leak. If no bubbles appear then set the gas valve to the pilot position, remove the gas line marked "out" (the left one) from the gas valve. Turn the gas valve to on. The burners should turn on. Place you finger over the hole where the disconnected line was and the burners should turn off within 10 -15 seconds. If this happens then the thermostat is your problem.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Nov 10, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Wont come on
low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Aug 04, 2008 | Vulcan EF3 Deep Fryer
Imperial IFS40 Deep Fryer Logo
378 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
