Question about Kitchen Appliances - Others
Toaster 6595 lever won't stay down
Have already cleaned out all crumbs
  • 277 Answers
SOURCE: lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Posted on Mar 30, 2006
Noggin
  • 944 Answers
SOURCE: Toaster Loading handle wont staY down
I have researched this toaster quite extensively, without any success as to actual solutions. Usually these machines have either a solenoid activated lever that holds the toast down, although magnetic systems are not uncommon. These may be avtivated by a thermostat, an optical "brownness" meter or a timer. Usually the cost of replacing this would be as much as a new toaster due to labour costs, however it may possibly be fixable - could you add a photo of the internal workings - this might help. Unfortunately many other purchasers appear to have similar problems and claim to have had little success with either dealer or manufacturer. The number of toasters of this model offered for sale second-hand as new at ridiculously low prices makes me suspect that there is a fundamental problem with the model. Use any warranty you have, but unless you wish to write a lot of letters/mails then i suspect a new toaster might be your best bet. Availability of spares for this toaster is another issue - I have been unable to find anyone who claims to supply these, although individual components are almost certainly from different manufacturers and could be sourced. If you can arrange a photo of the toaster when open (reasonably close up and general view) then I may be able to help more. Apologies for no actual "Solution" yet.
Posted on Feb 17, 2007
snakehead
  • 1074 Answers
SOURCE: Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Posted on Feb 25, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
Kitchen aid toaster won't stay down, heats when held down, but only on bagel setting. Checked crumb tray but all clean. What to do?
Contacts may be coated with Burt oil, butter, other matter. When engaged, contacts aren't engaging.
Aug 31, 2014 | Kitchen Appliances - Others
Toaster will not stay down
Just fixed mine, shake the crumbs out really well, take tray out and clean it. If there is a large crumb (like fell out of mine after vigorous shaking) they get caught where the lever comes down. Worked like a charm after.
Oct 29, 2013 | VillaWare Mickey Mornin' 5555-11 2-Slice...
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Toaster won't stay down. Toastmaster Toaster
The contacts on my magnetic lock (lever) had some crumbs and build up on it. I had to take it apart but just cleaning it made mine work fine again.
Sep 21, 2009 | Kitchen Appliances - Others
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Lever won't stay down Breville CT20
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Kitchen Appliances - Others Logo
35 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
