Question about Garden
When I push forward on the paddle to move forward, it moves very slow.
  • 13 Answers
Not overly familiar with Audis but it sounds like either a.) you have an electronic tranny that has a serious bug or b.) there's a problem in the computer of the car itself. What is sounds like is the car is taking a long time to "understand" that you're telling it to move forward. How new is the car? When you push on the gas before the three minutes, what happens?
Posted on Oct 21, 2008
  • 3 Answers
SOURCE: Front driver seat adjustments.
I just had this problem fixed with a Tech 2 tool in my '03 yukon xl denali. The seat has a control module underneath of it that controls the 2-position memory, the power seat functions, etc. It needed to be reprogrammed - about $200 at the dealership, or free if you 1) have a good relationship with your service manager, or 2) own or know someone with a Tech 2 tool.
At first I thought it was because I had a Canadian model truck (the headlight switch is stuck "on" at all times no matter what position it's in, and the rear air controls are in celcius and not farenheight).
I'm assuming the switch worked before, and you may have encountered some sort of electrical issue (like a dead battery, or you gave someone a jump, you have a bad ground, you just installed an aftermarket stereo, you used a computer tuner, etc.).
Hope this helps!
Posted on Dec 30, 2008
  • 16 Answers
SOURCE: My riding mower workes fine fore about 45 mintes
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Posted on Jun 13, 2009
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ (remove the spaces)
Posted on Jun 18, 2009
Stalls when you let out the clutch
push the Gas paddle too when you let the clutch paddle to pull back . Simply to say use clutch and gas alternately and opposite to each but with slow moments . if it stalls , simply when you push the key to ignition the starter motor moves to torque the engine , YOU MUST PUSH THE GAS TOO TO START THE ENGINE WHILE IT TRIES TO START .
Apr 07, 2016 | Garden
How can I fix my mobility scooter. when the forward paddle is pulled the scooter moves away then begins to slow to almost a stop
Sounds like you need a new paddle switch? If you can get inside it you could try spraying it with WD40.
Jan 20, 2016 | Health & Beauty
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
The mower with not move! I put it in forward push the gas paddle and it will not move. It just wont move, it has a brake paddle and a gas paddle and brake. All yard machines basicly have the same setup in...
Inspect the drive belt,if it is broken.Under the hood is a list of parts and part numbers.Find the drive belt on there and get a replacement.The package the belt comes in has the diagram for installation on the back.Would not be a bad idea to go a head and change the deck belt if it is ore than 2 years old,while you are under there.
May 12, 2011 | Yard Machines 155 Torque Briggs Stratton...
Bottom oven goes off with F64 message
If you look under the bottom door you will see a 3/4" tall slot the entire length of the door. This is where the cooling air blows out. In the middle of this slot is the air switch enclosed in a 5" long metal housing. You can see a thin metal paddle sticking out of each side of the housing. These paddles are spring loaded to angle slightly back. When the fan is on, the airflow will push the paddles forward. If they do not move forward, then you will get the error code. The simplest solution is to vacuum out all of the normally collecting dust that keeps the paddles from moving. To better access and clean the area, the black trim piece that forms the slot can be removed by unscrewing the two retaining screws. That can be more easily accomplished by first removing the lower door. This is very simple. With the door fully open, rotate the small metal clip on each hinge so it hooks over the protrusion on the other part of the hinge. Then lift up on the door (close it part way) and slide (pull) the door and hinges out of the hinge slots. There is no need to remove the entire unit from the wall.
Apr 19, 2011 | Thermador Ovens
Error message F64 appears when lower oven is turned on.
Hello,Note that lower oven cooling fan air switch not detected and that means you have to replace air switch,replace cooling fan,check connections,check P6 on PCB control display.
May 31, 2010 | Thermador C272 Electric Double Oven
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Oct 21, 2008 | Audi A4 Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
