Question about Welding Tools
I have a gas powered TB 302. I have power to weld but only a trickle from outlets.
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: No power to weld or use A/c power outlets
You don't say what model welder you have, some Miller welders have 3 slip rings and brushes some have just 2. In either case the next step is to use an ohm meter to check the resistance of the rotor and brush assembly. If this is a 2 slip ring model, take one of the wires off of one of the brushes then measure the resistance between the 2 brush terminals - it should be something between 10 and 100 ohms. If you get an open circuit measure the resistance from one slip ring to the other right at the slip rings - if you now get something other than an open you've got bad brushes (about $10 each to replace),
The 3 slip ring models are similar but have 2 rotor windings - take off the wire from the middle brush and measure from it to each of the ends.
If your rotor and brushes checked out OK you should next check the fuse in the exciter circuit, this will be on the block where the other end of the brush wires go.
If the fuse was good you need to do an excitation test. This is a bit dangerous so be careful. Look at the schematic pasted inside the case and figure out which brush is the positive (+) one. The wires are numbered and so is the schematic so this isn't as hard as it might seem.
Disconnect the wires from both brushes (all 4 wires in the 3 slip ring model) and tape them off so you won't get shocked. Get a 9V battery or make up jumpers that will let you connect the welder battery to the brushes. Start the welder and connect your temporary power supply, measure the AC at the outlets (it should be around 60VAC with a 9V battery) and the DC voltage at the weld terminals (should be above 10V), lastly measure the voltage at the wires you disconnected from the brushes (should be around 70V DC). Disconnect the temporary power supply and shut down the welder.
If you didn't get AC at the outlets and DC at the weld terminals above, something is wrong with the stator in your welder. If you didn't measure any DC on the wires that go to the brushes (most likely thing to happen), you've got something wrong in the exciter circuit. Check the rectifier, the capacitor, the exciter winding in the stator, and lastly the current control board. Older welders will also have the fine current control rheostat in this circuit (look for burned windings on it).
That's about all of the general advice I can give you without knowing more about which welder you have.
Carl
Posted on Dec 02, 2008
  • 11 Answers
SOURCE: karcher k2 power washer inlet-outlet manifold cracked along weld
well depends did u use it in cold tempatures if so no it was u. if not then most likely or could have been just a crazzy thought here that there was a electrical discharge when it was pluged in and cracked the block on it but honestly thats 1/10000000000000 chance of happening. or it overheated and cracked it but relistically if its new then just take it back and play dumb or if its still under warrenty play dumb and get it fixed. aslo u can search for a new part on craigslist or ebay. last but not least if its not uner warrenty or new to take back or u cant find a part either thru the ones i listed or by calling the man. ur last resort is to just throw it away.
Posted on Apr 03, 2009
  • 1212 Answers
SOURCE: Have Miler Trailblazer 302.. it will start but wont weld and the outlets dont work either.. what could be the problem?
Switch S1 may be dirty or damaged. The field should not need flashing as that will occur when you engage the start button.
It is possible there are some faulty connections in the 24 volt control section. Loose or corroded 24 volt connections to the contactor may not be allowing adequate current to flow. The connections on the SR 1 board should be checked as well. Also check the rectifiers. THey should be moderately high in resistance with test leads held one way on the rectifier, then with leads reversed, the resistance should be at a minimum 10 times different than the first reading either greater or lesser. Use a decent DMM to test them.
Posted on Jan 07, 2012
  • 1212 Answers
SOURCE: Out in Afghanistan using the 302 and when i press the trigfer to start mg welding the power supply to the remote unit cuts off. any suggestions?
If it is only momentary, it may be sand in the contactor- blow unit clean or as best you can and "tent" some poly plastic over the contactor with duct tape to seal it to cabinet. Use the heavier 6 mil stuff or fabrcate a cover from phenolic sheet or fishboard (flame proof material looks and feels like cereal box cardboard)- old circuit boards from derilect equipment, etc also can work, the idea is to dust proof the contactors- the heavy one especially.. Check to make sure it does not melt either as it will get exrra warm there. They were made for a metal shop not a desert. No offense intended.
Also check to make sure the circuit breakers CB1 and CB4 are sound- they can fatigue fail and/or wire connections work loose and become intermittent under load.. Also cycle the switches a few times to clear the crud. If you have LPS1 available- it can help clean the contacts and dries without residue.
Also check the trigger switch and replace it if you can find no other obvious faults with an ohm meter. If not, the microswitch might come apart to clean up the contacts. It "might" even be interchangeable with.derilect mcrowave interlock switches- which would need to be sealed with silicone out there.
If you do not have the manual for it from Miller, you can download it from their website
http://www.millerwelds.com/service/ownersmanuals.php?model
then just scroll down to the flavor of 302 you have. Engine controls are the only real difference between the three models
Lesser possibilities are an issue witht he current sense coil- PLG-6 attaches there- also check that connection. They would be wires 141, 142, 143, 144 They go to the main board.
Also check RC-12-1 and RC-12-3 these will be on the PC-2 board- they are the voltage sense wires and they go to switch 1.
Also check SR-1 the rectifiers- make sure they are not loose or have faulty soldering- this can drop out the voltage too.
Posted on Sep 25, 2012
My TB 302 cranks and runs at high idle does not idle down. I have power at all recepticals but no power at welding leads. I have checked all breakers and fuses, they are ok. what do I need to do next
there are a few things you can check on your machine,
make sure your machine is not in the remote control position, make your process switch is in the electrode hot position, the trailblazer has three slip rings, make sure the carbon brushes are not "stuck" in the holders, there are 2 circuit boards in your machine, make sure the plugs are properly inserted into the receptacles and making good contact, also make sure your ignition switch plug is clean and making good contact
Mar 17, 2016 | Miller Trailblazer 302 AC/DC Welder...
I have miller 302. Outlet power working but stick weld not work
Check your machines fuses. For location of fuses look into your owner's manual.
Feb 17, 2014 | Miller Trailblazer 302 Welder Generator...
Jan 07, 2012 | Miller Trailblazer 302 Welder Generator...
Miller Trailblazer 302 Gas, will start but, but won't weld or generate. Does not show any readout on the digital meters, will not idle up, only idles at low RPM's. Any idea what may have...
Check the circuit breakers, one may have tripped or failed, such as CB4 which would also impact generator voltage output and since it controls power to the 24 control system- the first one to check or service. If you can access the rear terminals, check the voltage in operation at both lugs- if you do not get the same voltage reading at each lug of CB4 measuring them one at a time to chassis ground, the breaker is tripped or faulty .
CB1 is inline with the 240 VAC outlet and is ahead of CB2 and CB3
CB2 and CB3 are inline with the 120VAC outlets
In each case, switch them off then back on.
If you have the GFCI option, it may have been tripped by unsafe conditions.
Sep 20, 2011 | Miller Trailblazer 302 Welder Generator...
How i can use wire feer x-tyrem with a cp-302 welder
Hi:
An easy one: Connect your Suitcase X-treme 8 or 12 VS (volts sensing) as follows:
Weld Cable (+) To Feeder lead cable.
Work Cable ( - ) To Workpiece Weld cable and work cable connections to power source (DCEN/DCEP) are dependant on wire type.
Since feeder is not polarity sensitive, there is no need for an electrode polarity switch.
Voltage Sensing Clamp Connect voltage sensing clamp to
workpiece.
Gas Hose to regulator.
Gas Cylinder to regulator.
Use of shielding gas is dependant on wire type.
You are all set up to weld.
If this was useful. Please vote.
Feb 22, 2011 | Miller Electric Mfg Co 903376 Deltaweld...
How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Mar 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Gas won't shut off until power is shut off
With a tig welder it is designed to do this. The gas is used to shield your weld of all airborne contaminates. Your welder should have a flow on start of weld and what they call a post flow. This post flow protects your finished weld from contamination. You can preset it from 0 to 30 seconds on a majority of welders. I would recommend you set a postflow for at least 10 seconds and hold the torch above your finished weld until gas shuts off. It is doing this for a reason! Too Protect your weld from oxidation and other contaminates while the molten weld pool sets up! Hope this helps out!
Dec 28, 2009 | Welding Tools
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
Welding Tools Logo
274 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
