Bios and hdd password for remove
  • Computers & ... Master
  • 247 Answers
To speak Microsoft outlook Customer Support representative dial +1 (800) 204-4427 (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Our highly trained and experienced technicians have deep knowledge in fixing different types of all type technical problems and have extremely high success rate in troubleshooting. To use our reliable tech support services, please call our toll-free Tech Support Number at +1-800-204-4427.
Posted on Apr 26, 2017
SOURCE: Bios Password
From what I remember a bios password is easy to remove in some Toshiba laptop models. You just remove the battery. Pull the RAM out (make sure you are grounded when doing this--at a minimum don't walk around or shuffle your feet while touching the RAM) Under the RAM there should be a piece of mylar tape. (shiny brown or black) That should expose 2 or 3 solder welds where no component is located. Take a paperclip and make contact with the welds for at least 10 seconds. This should short out where the bios is stored.
For the HDD issue this might work:
Try F8 before the system POST(s) to get to ADMIN account in safe mode. Then go to control panel and user accounts and remove the password. This only works depending upon your OS. Good luck.
Posted on Feb 14, 2009
  • 117 Answers
SOURCE: i want break my hdd password and laptop bios password
Bios password can usually reset by removing laptop battery and clock battery from motherboard, but HDD password as i know cant remove. You should change your HDD.
Posted on Apr 09, 2009
  • 432 Answers
SOURCE: Hdd password frozen on laptop
if you download the sata drivers from the toshiba website for your specific laptop and then extract them and get nlite ( and slipstream the drivers into the xp disc you can then re install xp and it should allow you to boot.
As for the hard drive frozen password that should be in the bios on the hard drive that you set it for so it should remember it
if not you may have to contact toshiba and they should have a back door password that they can produce once you give them the asset tag ( serial number of the laptop ) and once you enter that it should resolve the hard drive frozen issue.
Had a hard drive frozen at a school once and had to call dell ( as it was a dell laptop obviously ) and gave them the serial number and they created a back door password for me - jobs a good one :D
Posted on Apr 29, 2009
  • 662 Answers
SOURCE: How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
Posted on Aug 29, 2009
  • 1189 Answers
SOURCE: dell vostro 1000 laptop hdd
  • Hello misdept, if by chance you didn't 'create a "Supervisor Password" to prevent anyone from changing the configurations in the BIOS / CMOS Setup? than we are 'OK!' Lets just say [No] for now. Bootup / Start the computer, and follow these steps: 1. When you hear the computer start-up, there will be a message that flashes very quickly at the bottom of the screen, it will read; Press F2 or F12 or on other "Computers, the 'Key Sequence may be [F11]..." The area of your attention will be [F2] Key at the top of the keyboard. The F2 Key will open the CMOS / BIOS Setup. paul7of9_15.jpg 2. Once this screen appear, you will see a 'Listing" of different set-ups. There will be instructions in the [right] Help ? area. You be using the "Arrow Keys" to (Select and Choose Items). In the first screen, there will be on the (right of the screen). 3. Set Supervisor Password = This is the "Password Setting that will prevent anyone from getting into without authorization this area that you are in now, to "Change or Configure" CMOS or BIOS setting. 4. Set User Password = This Password is use for "Logins / User Accounts... You want to "Reset or Change the Supervisor Password. Do so, and to finish; remember to use the [F10 Key] to 'Save the Changes.' Thanks for using Fix' Ya, and I hope this fix it, paul7of9
Posted on Dec 15, 2010
Forgotton hdd password on Toshiba satalite oro a210
you could try this,,,Others have been able to change the password in BIOS. Found this:
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice
Apr 03, 2017 | Toshiba Computers & Internet
How do I remove a BIOS or HDD password from an ACER laptop computer
This is the response from Acer America Tech support about removing a lost BIOS password:
Thank you for contacting Acer America. I apologize for the delay in responding to your inquiry. In order to have the BIOS or hard disk password removed (This include any biometric security), the notebook will need to come in to our repair depot for password removal. This service is not covered by warranty and unfortunately there is no other recourse to remove a BIOS or HDD password from the notebook. The flat fee for BIOS password removal is $100.00 US dollars plus tax. If it is a BIOS or HDD password and you would like us to service it for you, please contact our telephone technical support line at 1-800-816-2237. Hours of operation are 7am-9pm CST Monday-Friday and 8am-5pm CST Saturday and Sunday, excluding holidays.
on Jan 15, 2010 | Computers & Internet
How to remove BIOS password and sata port 0 wdc wd5000 bpvt for dell 5200
You cannot erase the hdd password. You cannot use the hdd until the correct password is typed.
Dell may tell you how to get in to the bios.
Jan 19, 2014 | Dell Computers & Internet
Trying to remove or reset hdd password, cannot get to bios
Hard drive password is difficult to remove. These WEB sites maybe able to help you.
HARD DRIVE PASSWORD UNLOCKING - Purchase A-FF HDD Unlock Wizard (HDD Password unlocking - Free) .
Sep 10, 2012 | Gateway MX Computers & Internet
Finding the primary hdd passwor on a dell inspiron 1300
- You will get the Master Password that will remove both Admin/System Password.
- Also HardDisk unlocking.
- You don't need any additional tool (no paperclip...)
Bios Password - HDD password - Master password - Unlock laptop - Reset bios password - Bios password removal - Bios Password Recovery - Clearing the Bios or CMOS Password
Apr 03, 2011 | Dell Computers & Internet
I have laptop dell inspiron 9400 and it is lock with bios password please help me to unsecure my laptop code : J6VYT2J#-595B
Bios password differ for every model, try with the below mentioned password to unlock it.
If not you have to reinstall the OS.
Thank you
May 14, 2010 | Dell Inspiron 9400 Notebook
Bios password
Feb 15, 2010 | IBM ThinkPad T43 Notebook
I want break my hdd password and laptop bios password
Apr 09, 2009 | Acer Aspire 4720 Notebook
Remove your hard drive.Reboot computer.
While its rebooting press F2 to enter the BIOS
Press Alt-F to restore BIOS defaults
Replace the hard drive
Sometimes your computer vendor ( Dell, HP. etc)
maybe able to reset HDD pwd depending on model
Jan 04, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
