Question about Home
I would like to receive an explanation of how all the parts operate in the Perfecta SWP1-SWP2 tank. I was told that the toilet does not flush properly.
How far should the water level be from the top of the tank?
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
for your help
Posted on Jan 18, 2009
  • 659 Answers
SOURCE: valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Posted on Apr 02, 2009
  • 308 Answers
SOURCE: super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Posted on Jun 17, 2009
  • 2600 Answers
SOURCE: toilet keeps filling tank every 10 minutes
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
Posted on Sep 11, 2009
We have a Jacuzzi swp1 and swp2 it run's and will not fill up
Worn or defective flapper at bottom of tank
Dec 15, 2016 | Jacuzzi Home
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
I have a Jacuzzi Perfecta SWP2 toilet. It worked good for a while , now when you flush it you have to jiggle handle to make the flapper fall.Lowes doesnt have a replacement so they sold me a Fluidmast
If you have to jiggle it it usually means the chain is longer then it needs to be so its getting caught on something, the jiggling just loosens it. Look inside when you flush to see whats happening. Metal chains also get wound up when too long and the same thing happens.
Aug 17, 2014 | Home
We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Jun 01, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Let my tank freeze and crack on the perfecta model EZ33 959. Where can I order a new one
If the tank froze and broke it is highly likely the toilet itself may have a crack somewhere inside. You may buy the tank and find out later on the toilet itself it cracked. You have then wasted your money. Buying the tank and paying the shipping is more than likely about as much as a whole new toilet. My advice is to buy a new toilet.
Jan 08, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
How tight is the tank/bowl supposed to be a
They only need to be tight enough to sufficiently seal the donut between the tank and the bowl. Some movement is acceptable. It is better to be a little loose than to overtighten them and risk cracking the tank.
Oct 20, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Tank has slight wobble after installation
you need to tighten the nuts under the tank. the tank is not even.
The best method is hand tight the nuts to approximately same pressure on all 3 nuts. then use socket ratchet, one turn each,one at a time, till the tank stop rocking. stop right there. flush the toilet, check for leak. tighten as needed.
make sure all 3 nuts have even pressure.
May 20, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
26 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
