Question about The Computers & Internet
Start menu left click stopped working. Right click okay. Windows 10.
When I left click on the Windows 'Start meno lower left, it no longer works.
  • The Master
  • 4,207 Answers
I have found a similar problem at a windows 10 forum
Suggest you look at the forum as it may help your problem
https://bobmckay.com/cloud-sass/solved-left-click-not-working-windows-10/
Posted on Apr 26, 2017
serra_baby
  • 144 Answers
SOURCE: Mouse Right click doesn't work
hello!
o Install fresh batteries. Try brand new-high quality batteries you absolutely know are fresh and working.
o Install the latest software. Totally remove all software and reinstall from scratch.
o Try a different port and Resynchronize your device to the receiver. Try plugging the mouse into a different USB port try powering down the computer and using the PS2 port for the mouse instead. Mice in my experience overall work better using PS2 ports on PCs that have them.
o Clean the mouse lens. This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty.
Posted on May 08, 2008
Fame_Guru
  • 483 Answers
SOURCE: asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Posted on Mar 16, 2009
rtrahan
  • 741 Answers
SOURCE: Right and left click are working backwards
Go to control panel, mouse, buttons tab, uncheck "switch primary and seconday button"...
Pls rate this solution.
Posted on Apr 07, 2009
  • 1986 Answers
SOURCE: rear left and right turn signal lights not working.
the electronic flasher module may be faulty, or you could have blown a fuse
Posted on Aug 13, 2009
jasoie
  • 11 Answers
SOURCE: left click button below touchpad on dv8000 not working
Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Posted on Jul 22, 2010
My Windows 10 computer can no longer find my printer.
try removing printer from control panel - printer and devices (right click start icon bottom left corner - select control or settings from menu - I don't use windows 10 much !)
then right click on start and select system . Note the Windows operating system and if it is 64 bit whether it is windows 10s or windows home edition .
Then go back to hp driver download web site and download the matching driver with your printer model and operating system.
Run driver install program you just downloaded to install driver and it should find your hp printer and set it up in windows.
Feb 21, 2018 | HP Office Equipment & Supplies
Tip
Windows 10 - Start Menu Fix
How to fix the Windows 10 Start Menu when you can only right click on it:
1. Right Click the Start/Window button on the bottom left corner of the taskbar.
2. Select "run command prompt as administrator"
3. Type in the word "powershell" without the quotes and hit Enter. Wait a few seconds to process the request.
4. Copy and paste the block below and hit Enter. It will take about a minute to process. Don't close the window, just wait for the command prompt to reappear. Then your start menu button will work again!
Regards,
Terry Wilkie
Get-AppXPackage -AllUsers ' Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
on Aug 16, 2015 | Microsoft Computers & Internet
How do i uninstall it?
Uninstall Chrome in Windows Vista/ Windows 7/ Windows 8
  1. Close all Chrome windows and tabs.
  2. Go to the Start menu > Control Panel.
  3. Click Programs and Features.
  4. Double-click Google Chrome.
  5. Click Uninstall.
  6. If you want to delete your profile information, like your browser preferences, bookmarks, and history, check "Also delete your browsing data."
Mar 18, 2016 | Google Chrome
How do i fix the shifting in color problem?
Go to your "printers and faxes" in your start menu (or equivalent menu, depending on version of windows). Right click on the printer and select "Printing Preferences". Select the "Image Color" tab. Find the selection, under "Heat", labelled "Dye-Sub Intensity". Click the scroll tab, and drag to the left. You want to lower this to -%10.
This will lower the heat used during transfer.
If the Problem persists, try updating the printers firmware.
Aug 09, 2014 | Fargo HDP5000 Thermal Printer
How can get driver for Wind XP
There are no drivers user loaded, the instruction is in the cd / dvd disk drive already from the factory, but when you load the OS, it has some included... these have been known to become corrupt or filtered...
In case windows no longer recognizes the cd dvd disk drive, as if the disk drive driver were erased...
left click start in the lower left hand of the screen
left click run
type regedit
left click OK
Now the registry editor will come up
double left click on HKEY_LOCAL_MACHINE
double left click on SYSTEM
double left click on CurrentControlSet
double left click on Control
double left click on Class
double left click on {4D36E965-E325-11CE-BFC1-08002BE10318}
look on the right side of the window for upper filters
right click on upper filters
left click delete
windows will then ask you to confirm deletion
click yes
look on the right side of the window for lower filters
if you do not see lower filters, you may be out of luck on this one.
right click on lower filters
left click on delete
windows will then ask to confirm deletion
click yes
Close all the windows that are open
restart the computer
In many cases that solution worked, in some cases setting the system back to a previous time, using system restore, was able to reset the system to the time before the system stopped recognizing the drive.
Jun 04, 2013 | Computers & Internet
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
The dvd player will no longer play any disc except cheap free bees from the uk, it will no play uk or australian discs and the error msg reads please check region code.... have tried the 8,4,2,6,9 hack to...
If your drive reads cd's, but not dvd's That indicates that the hardware works fine. You will need to edit the registry in order to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters in the right side window or whichever either/or is in there, close out.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) restart computer
after restarting, windows should automatically install a clean ROM drive and it should read DVDs just fine if you have the correct DVD decoders.
Hope this helps,
-samson39
Jul 26, 2009 | Computers & Internet
How reboot my satallite pro laptop
To reboot a windows computer with Windows XP, click the Start button in the lower left corner, then click Shutdown, then Shutdown again in the popup box.
For a Windows Vista machine, click the windows Orb in the lower left corner, then the small arrow next to the lock on the bottom right of the start menu then click shutdown.
If you need to manually power off, hold the power button down for 5-10 seconds until the computer itself shuts off. This is only for when traditional methods do not work.
Jan 12, 2009 | Computers & Internet
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
