Question about Air Tools & Compressors
Price and availability for a part for a 68027 nailer
I have a Hitachi NR 83A2 nail gun, it still fires a nail, the firing pin retracts but then slowly comes out and stays out. Is there a seal kit available for this problem?
Sounds like you have worn valves or damaged o-rings. Unfortunately Hitachi does not make a rebuild kit for your nail gun. If you go to www.ereplacementparts.com you can find an excellent breakdown of your tool and either order the parts you need there or use the part numbers to search the web for prices and availability. Your tool is on the old side and some parts are no longer available.
Feb 26, 2013 | Tools & Hardware - Others
Where can I buy a o-ring kit for a bostitch nailer #sb1850bn ?
Stanley Bostitch makes very few o-ring (rebuild) kits for thier nailers. Your brad nailer never had a kit available. You have to go to a service center or website like www.ereplacementparts.com, find a breakdown of your model and order each o-ring seperately. Your nailer is an older tool that was sold as part of a combo kit and there are many parts that are no longer available or are shown on back order which usually means the same thing. If you have someone in your area that works on pneumatic nailers they may have o-rings from other manufacturers that will work.
Feb 22, 2013 | Stanley Bostitch SB1850BN 18Gauge Brad...
The door in front of the driver is broken on my N60 and the part [p/n N60005 ] has been discontinued ,any ideas on where I could get one ?
This part is not a fast moving part so most likely not stocked by many repair shops, however when a part is discontinued there are still many new and used parts out there. Contact fastener dealers in your area for a new or used part or the whole gun used (most likely will sell cheap). Pawn shops / ebay etc, usually sell used nailers for very low price, most likely less than cost of part new if it were available. If you consider buying a used gun for parts, check into n59fn or n60fn, use same part. Good luck
Jan 11, 2013 | Stanley Bostitch Air Nailer Trigger N60...
Need breakdown of feed tube
If you go to www.ereplacementparts.com they have an excellent parts breakdown with all the part numbers available. You can also buy parts there or use the part numbers to search the web for prices.
Mar 13, 2012 | Air Tools & Compressors
Feed tube breakdown
Mar 13, 2012 | Hitachi NR83A2S Framing Nailer, Full Head,...
Just got a Dewalt D51825 Framing Nailer that takes 2" - 3 1/2", 30 - 34 degree paper collated clipped head nails. What is the best source for these nails, including recommended brand? Will it...
Your nailer uses a very common and lowest price nail when using bright nails. Other varieties are expensive, stainless, twisted, galvanized, so if you are a big user not a problem. I on the other-hand do not use very many nails in a years time. A case of nails will last couple of years. A box of stainless or galvanized will be an expensive proposition. Because of the weight of case of nails, shipping is very expensive unless you find speicals. At www.toolbarn.com , you will get free shipping for orders of $200 (less than 70lbs). Best bet is to find local dealers, and right now because of the economy, special pricing. Look for deals on broken cases of nails. I usually find broken/open cases of nails at Lowes for half price. Buy what ever you come accross that is a good price because nails have a long shelf life if you can keep them dry. Good holiday
Dec 29, 2010 | Dewalt Clipped Head Framing Nailer
I have a 16 ga D51256 air finish nailer.I WOULD LIKE THE DRIVER blade kit D512565. I have talked to a service center tool guy who cross referenced and gave me the price and availability for me to pick...
Part number for the driver by itself is 623243-00 and is available from dewalt or www.toolpartsdirect.com. The driver kit is no longer available and the gun has been discontinued. Driver kit contained other parts including gasket, lube and likely the lower bumper. Good luck
Sep 16, 2010 | Dewalt Tools & Hardware - Others
Need nails
Do a search on Google or Yahoo to find sellors and prices.
Mar 23, 2009 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
I need a repair manual for a duo fast striper nail gun.model#325b
Your nailer, although very good, is rapidly becoming obsolete as many parts are no longer available. When these guns were first made available, a sales rep. demonstrated repair techniques and did not provide repair manual. Owners manual for many models are available at duofast.com www.toolpartsdirect.com has parts lists and many parts available. If you are having a specific problem please post it; maybe I can help. Good Luck
Jan 11, 2009 | Hitachi 3 - 1/4" Framing Strip Nailer
Air Tools & Compressors Logo
166 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
