Question about HP Garden
Valve settings on 19 hp Briggs riding mower oh single cy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 903 Answers
Should be .004 and .006 i set them both at .005 and they run like new
Posted on Apr 25, 2017
John Deere 19 hp single cy ohm riding mower/ valveadj
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 25, 2017 | John Deere Garden
Valve settings.
you will need the model and type numbers from your engine to find the correct clearance numbers
Nov 15, 2015 | Bolens 13.5 HP Manual 38-in Riding Lawn...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What briggs valve gap lt1000?
Briggs opposed twin cylinders don't have valve gap. Single Cylinder OHV & V- Twin OHV do.
Jul 13, 2014 | Briggs & Stratton Garden
Briggsload Stratton 14.5 HP single cylinder OHV gasoline engine has episodes of severe smoking when
When what if you are saying when starting..after sitting..the oil from your overhead valves are seeping into the heads through open valves..when not running..most likely bad valve stem seals...
Apr 12, 2014 | Briggs & Stratton Garden
How do you set valves on a riding mower with a 13.5 h.p. engine
a briggs over head valve engine turn the engine til one valve opens set the other valve to .006 turn til the other valve opens then set the closed one to .006 it not the text book way but it works for me
May 08, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Cant find motor Model number on Bolens MTD 2005 Riding mower 15.5 hp I/C OHV
Per your own question that is the model # just use the 13AM762F765, There should have been a 2nd set of numbers and those would be your Serial number 9 digits followed with (000005) which is year built. I have exact same mower
Mar 04, 2012 | Briggs & Stratton Garden
I need to know the over head vave setting for the intake and exhaust on a 17.5hp Briggs & Stratton vertical shaft, single stroke lawn mower.
hi pauly46 here
set piston to tdc compression stroke then run it down the bore a 1/4 inch
set the tappetts to inlet the bottom valve ( alloy push rod ) to a tightish 0.004" and set the
ex valve the top one ( steel push rod ) to 0.005"
setting at 1/4 pst tdc eliminates decompressor from upsetting valve clearance seting
cheers pauly46
Mar 26, 2011 | Briggs & Stratton Garden
Garden Logo
32 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
